It can be fixed but probably not at a cost that is inside the worth of such a deck. You are better off getting an older designed unit made with good parts such as a Teac that has been restored by a professional and then be on your way. The cheap plastic decks are made for throw away systems and are not often repaired. I have been doing repairs for about 42 years so I know about these things. If you need a well functioning deck you might want to contact me directly at Skywave Tape Deck Repair in the Chicago area.
SOURCE: WE475 Sony Dual cassette deck
Hi - You can download the manual from the link underlined in blue below:
WE475
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: Sony TC-WE475 problem when taping A to B, B is not
Hey there,
Next time you have a few minutes, open the B side of the tape deck and look at the actual tape head- if it is dirty, you can clean it using cotton swabs and 80% isopropyl alcohol. (Higher than 80% is actually better, because it has less water in it)
Let me know if this helps your problem,
HortonA!
