HP PhotoSmart 1215 InkJet Printer Logo
A
Anonymous Posted on Sep 07, 2013
Hp printer 7283 orginal ink depleted - HP PhotoSmart 1215 InkJet Printer
3 Related Answers
Anonymous
  • 81 Answers
  • Posted on Dec 16, 2008
SOURCE: How to align my HP DeskJet 694C ink cartridge
Hi, have you tried another cartridge? Sometimes if a cartridge has been sitting around for a while, they become blocked with dry ink and print quality gets poor.
Anonymous
  • 3917 Answers
  • Posted on Apr 14, 2011
SOURCE: I have a continuous ink supply system. There is
Hi
Please check this link bellow to have a detailed idea related to your issue:-
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720676&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1153756
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c01370564&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3204785
However if you believe the cartridge should be OK, try wiping the print head on the cartridge with a moist tissue. (Deionised water is best to moisten the tissue, some hard tap water may make the problem worse).
Wipe the print head from front to back until you get a black line, or three colour line on the tissue. Reinstall the cartridge and try again
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
inkjet411hel
Rod Eslinger
  • 307 Answers
  • Posted on Jul 26, 2013
SOURCE: hp 3310 all in one
I suggest you first activate a CLEAN PRINTHEAD routine from the TOOLS/MAINTENANCE menu to see if you can blow/**** ink down and thru the PRINTHEAD nozzle plate. You may also need to place a damp cloth under the printhead to help 'wet' the nozzle plate in an effort to remove residual black ink buildup...you can find some youtube videos on how to do this. For additional HP02 support information, please visit our HP02 system support page which includes videos of procedures below: http://inkjet411.com/?page_id=1372
The permanent PRINTHEAD may be electrically damaged (unfortunately it is not replacable); you can verify this by performing the following:
To bypass INK SYSTEM FAILURE message please see the HP Printer Diagnostics Tests file (pdf) for instructions: http://inkjet411.com/?page_id=1813
Verify the permanent built-in PRINTHEADs electrical performance inside this legacy printer model by running the TAP 43 diagnostic test (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
A. HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap 43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
1. Press * and # keys simultaneously.
2. "Enter Special Key Combo" will be displayed.
3. Press 123 to display the 'Support/Service' menu.
4. At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
5. Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
6. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
7. Select Ok. The test page prints.
8. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
B. HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
Internal Test Print:
1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
1. Turn ON the printer.
2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
3. Release both buttons.
4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
8. Select Ok. The test page prints.
9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
2answers
Color ink attention on my HP deskjet F2235(All-in-one) what may be the cause?
That attention mark is a reminder that the ink is in low level or it is already depleted (empty).
If you do have the hp solution center installed on your computer, try to check the Estimated ink levels or please print a self-test page.
To do that,
- press the setup button, (wrench like icon)
- press the down arrow, look for PRINT REPORT and press ok to select.
- now, press the down arrow to highlight SELF-TEST REPORT and press OK for it to be printed.
Check if there are any depleted cartridges.
Cheers!
1helpful
My printer will not print. It feeds through the paper but no ink why?
is the cartridges are orginal or refilled?
if orginal clean the cartridge with sperit and try printing.
if it's refilled change the cartidge.
3answers
My printer had the toner light flashing I replaced the cartridge with a new one but the light is still flashing. What do I look for now?
did you replace orginal HP cartridge? if you are change refill or any other kind of manufature cartridge , there is chip is not working properly, that's why ligh is blinking, use orginal HP toner or good quality brand
I just bought a new yellow ink cartridge, and when I put it in the printer says that the yellow ink is depleted. I changed the ink two times. What should I do?
If you are using off brand cartridges that are remanufactured (refilled), that may be your problem. I have had several HP printers and when I used refilled cartridges, it wouldn't print. I stay with genuine HP ink cartridges. Just my opinion!
It won't recognize new black ink cart.
Hello, is it orginal hp ink? also check the cart connection in printer so its not broken. they are very sensitiv.
1helpful
What are OEM Ink Cartridges
OEM stands for orginal equipment manufacture so they sale the unit without the box but the equipment is with themanufacture of your printer., its the same ink
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2answers
Ink cartridge
I think you need to open your printers "Properties" and set and apply that new cartridges have been installed to get past the problem. It's been a while but I had to do this with mine last time I refilled them after they showed depleted.
k24674
Grand Canyon Tech
Grand Canyon Tech
