Dvd recorder set up
Hi i recently purchased a dvd recorder, and had a problem to hook it up with my tv and sky box. how should i connect them so i can tape things from tv?
    Novelist:
  • 159 Answers
There are some tv (sony) that you can get video and audio out from the tv and then is simple task to record what is in the tv. But maybe you don't have that option.
the second idea is this:
Think in the signal that comes from the box as a river and you need to divide this river (signal) before gets to the tv, so feeding the signal to the tv and the set you use to record then you have the option to record and watch the tv as regular; only task to do now is to monitor the recording in the input where you assigned for the dvd recorder. i hope is clear the idea to you!
Posted on Apr 14, 2009
  • jose martinez Apr 14, 2009
    there are some tv (sony) that you can get video and audio out from the tv and then is simple task to record what is in the tv. But maybe you don't have that option.
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
I recently purchased an LG RH397D dvd recorder> Ihave now discovered taht it will not receive the new free view channels and I need a HD set top box. How to I connect the set top box to the dvd...
Hi, The set top box will more than likely have two coaxial connectors ( threaded/ribbed pieces of metal ) coming out of the back. also three R.C.A. connectors-these will be smooth and be colored yellow red and white. one of the coax connectors will say " IN FROM ANT> or CABLE IN) the other ( OUT TO T.V. ) hook up your dvd recorders " ANTENNA " input to the set top box's ANTENNA output. If your D.V.D. recorder doesn't have an antenna input then hook up the recorders audio/video input to the set top box's audio/video output. then you should be good to go. If you buy a H.D.T.V. tuner to receive FREE H.D. programming it may be possible to hook up to recorder with H.D.M.I. cables.( those connections resemble slots ) I hope this has been of some assistance, good luck, Prodzilla.
Apr 02, 2011 | LG Televison & Video
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
I have recently bought a sky plus hd box and want to connect an external dvd recorder to it(Sony). Followed instructions but it will not pick up a signal from the hd box by the way I live on the costa del...
if you connect the dvd to the tv using scart socket 2 (av2) it should send a signal to the dvd, depending on the make/model of tv, you also may have to set the av2 output in the menu.
Alternativly, connect the sky to the dvd input and the dvd output to the tv, this should also work.May have to watch the tv with the dvd on set to av.
Nov 20, 2009 | Televison & Video
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Jan 18, 2008 | Televison & Video
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
