Question about Carrier 38CKC042 Air Conditioner
What FL stands for?
My air condition brand is a carrier.It is digital, recently an FL appear instead of the usual A(automatic).I cant determine what is the problem and FL stands for. I check my manual and it is not listed there.I hope you can help me on my problem. Thank You in Advance!
  • 625 Answers
FL means change filter media
Posted on Sep 13, 2007
SOURCE:
The digital box shows the letter FL. We cannot get maching to operate. We cannot get the FL off the box.
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*[email protected]$
Jun 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Am getting an FL error code and even though I have emptied the washer and unplugged it several times it will not reset. Anyone else ever have this problem?
“FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
Find the small clear hose that goes to the control and blow it out to get the sediment out so that the control can know when the right amount of water is in there. Resesure and pump out standing water before retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Calypso Whirlpool washer
FL= Flood Condition
realize that the trio was due to an
condition in order for FL to be displayed.
time out. The pump is cycled in drain mode
for 30 secondson 30 seconds off untill the
Note: Press STOP/CANCEL to clear display on all error codes
Causes of flood condition. Inlet valves
stuck on, Sediment in water level pressure
tube.
Other codes:
PF power failure
Er control lost settings during PF
LF Long fill Clogged inlet screens
CE Com error between motor and control
Ld Long drain Clogged/slow drain/pump
CA/CI Motor amping up
ob off balance load
Sr relay failure no control to motor
LS Lid switch no signal from lid switch, error occurs if the motor and control disagree as to the position of the lid switch. Usually means corosion is buit up in the switch and the motor knows the lid is shut but the control does not. Cose appears when start button is pressed.
open lid= flashing display time If the lid is opened time remaining flashes in display. Close lid and press start to continue.
SL Suds Lock Current draw on motor is sensed by motor control and a suds lock is declared The control trys 3 times to fix this by doing a mini cycle, SL is displayed if the unit was unable to correct the problem. This problem is caused by:
Bad pump
Extra heavy load
Excessive detergent
or Excessive suds/wrong stuff
Feb 04, 2010 | Washing Machines
GOING NUTS WITH WASHER
FL Flood condition"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. You will need to unplug this unit for 5 minutes. if you continue to hear beeps and the (FL) appears once more after the shut down, you will need to replace the water level switch.
Press STOP/CANCEL to clear the display and unplug the unit for 5 minutes.
Apr 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL Code
FL Flood condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
Apr 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washer won't drain
Flood Condition:
Mar 20, 2009 | Kenmore Washing Machines
FL ERROR MESSAGE
Hi and welcome to FixYa,
Initially, "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Dec 04, 2008 | Kenmore 24902 Top Load Washer
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%[email protected]
Dec 16, 2007 | Kenmore Elite 21082
Calypso wash motion washing machine FL code stuck
Calypso washers have been known to be problematic. In fact, there is a class action suit out there which could be beneficial to you: http://www.calypsosettlement.com/ According to Whirlpool FL stands for Flood Condition. Here is their explanation of it: ----- FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. ----- Hope this helps.
Aug 07, 2006 | Whirlpool Calypso GVM9959K Top Load Washer
Carrier 38CKC042 Air Conditioner Logo
799 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
