Question about Galaxy Radios DX-949 40-Channels Base CB Radio
Galaxy 949 Receive problem
Galaxy DX 949... transmitts fine on low and high power....nothing but static on the receive end.....gives me about a +20 on the s meter of nothing but static. antenna and mic is good....any ideas?
I had the same problem today 8/08/10 was installing a brand new galaxy dx 949 , i used a car lighter adaptor with positive and negative just to test the radio , wow the static was horrible, i think these radios need to be grounded well and power may need to be direct. am trying new installation in the morning will post results.
Posted on Aug 09, 2010
    Problem Solver:
  • 16 Answers
Is this In your home or car? If home you are probably next to a power transformer outside your home and its picking up the signal from the leaky power transformer. If its doing it from your car perhaps you need to better ground your system. Antenna should be properly grounded as well as your radio. If this does not work let me know............
Posted on May 27, 2009
  • 181 Answers
This sounds as the osolator has moved of freq. to check this you need to put it on a scope
Posted on May 22, 2009
  • norman May 22, 2009
    it sound as if the detector coil is faulty.
Low modu DX959
http://www.cbtricks.com/radios/galaxy/dx959_mosfet/index.htm
http://www.cbtricks.com/radios/galaxy/dx959/index.htm
Has links to pages to show you how the alignment is performed, plus a schematic if you need to trace the transmitter portion for faults..
Feb 22, 2012 | Galaxy Radios DX-949 40-Channels Base CB...
Can i use rg6 on my dx 949 radio that i am using as a base?
RG6 Cable is a 75 ohm cable and is generally used in residential settings for UHF/VHF off air antenna, cable & satellite TV signal feed lines.
The transmitter you have - like most CB, Amateur, etc. radios ant associated antennas have 50 ohm outputs and outputs. This is for a reason. Ohm's law says Maximum Power Transfer occurs when Resistance In equals Resistance Out. In order to achieve this, all the components must have matching (or close to it) resistance values. Inserting a 75 Ohm cable in a "balanced" 50 Ohm circuit can cause a mismatch or high SWR. There are ways around this - but it's too deep for here.
Your best bet would be to either try the RG6 and adjust the antenna for lowest SWR, or if unable to get it down to an acceptable value (less than 2:1 is the worst I'd accept - but 1.5:1 is significantly better), purchase a high quality 50 Ohm coaxial cable assembly instead. Good luck!
Jan 04, 2012 | Galaxy Radios DX-949 40-Channels Base CB...
Trying to find the right size linear amp to hook up to my Galaxy dx 949. I want max in/outputs. tired of being talked over. I have a Golden Eagle 150w amp, but have not connected it
That linear will be good for 100 watts of clean power. It has two MRF455 transistor which are 60 watts a piece. The cb will drive it with the carrier or dead key reduced to about 1.5 to 2 watts but i suggest that you read the linear's power while adjusting dead key not exceeding the 100 watts pep with voice. An NPC mod would be a good addition to get the modulation up with a low dead key.
Before you start the projection make sure you antenna system is in good condition high SWR will smake you linear in a hurry.
In factory condition 949 galaxy with a 3.8 carrier it will drive a 667v TexasStar. It is a low drive linear that will end all disputes as to who has more power. 8 out of 10 birds that escape will die of cancer withiin 72 hrs. Ok could not help myself. I would not suggest that unless you just want to damage other peoples receive. The v is for variable power. Hope this was of help.
Sep 14, 2011 | Radio Communications
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
I have a Galaxy dx 88 hl that don't swing
You will need a good technician. I know of a few but I do not like you to spend money again and again. Email me at...... poikaa@yahoo.com
Sep 14, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Will not transmitt after triple 520 final kit install,will receive fine
rather than use a small linier you decided to break your radio instead . It still sounds like a cold solder point to me .
May 26, 2009 | Galaxy Radios DX-66V Base CB Radio
It powers up....no modulation ...output power..or receive....just static...galaxy dx 949...
Sounds like the PLL may be toast. Either that, or someone has **** with the wrong potentiometers or tuning slugs in the radio, causing to to no longer resonate on the correct freqs.
Mar 02, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy Radios DX-949 40-Channels Base CB Radio Logo
353 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
