Question about IBM ThinkCentre M51 PC Desktop
IBM ThinkCentre 8183 (M51) does not boot
IBM Thinkcentre 8143 (M51) that no longer boots. The fans all power on, but there are no beeps, no monitor, keyboard lights up for a second and mouse lights is on. I have reseated RAM memory, but still does the same thing. I have an 80GB SATA HD. Any help would be greatly appreciated. Thanks.
  • Anonymous Mar 17, 2014
    I have IBM THINKCENTRE M51 and i need install windows 7 but in bios missing bookmark BOOT. Sorry for my english
    Novelist:
  • 166 Answers
The situation you describe is usually 1 of 2 things, Power supply (PSU) or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup. Fans are usually the first thing to get power, then the mobo for the Power on Self Test (POST).
Situation #2: You might get some power lights coming on and some fans spinning but the video output does not happen and normal startup sounds do not take place, usually indicates that motherboard is going out or has gone out. OR it may be due to a weak (damaged) PSU.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. These bad caps also affected power supply makers.
Since you have tried removing components then it looks like you have narrowed it down to either the power supply or motherboard. If your motherboard looks ok and if you can get another power supply that has an output watts that is greater or equal to the one that you have, try replacing that first.
Posted on Apr 14, 2009
IBM ThinkCentre M51 does no boots
different pc has different bios beeps depends on the bios manufacturer, but in your situation it is most likely you have problem with your video device. is it connected in video card or directly plug in the built in video port of the pc? if its connected in video card, remove video card temporarily then connect it to built in video ports, or vice versa, if your in built in video port you can try testing it with video card in pcie slot.
Feb 28, 2014 | IBM ThinkCentre M51 PC Desktop
Not booting
Try re-seating the video card or use a different video output port. Make sure all connections to the computer are secure, including monitor.
Dec 31, 2012 | IBM 8183-36u - Thinkcentre P4 Desktop Pc
I think it is more than likely your hard drive is the problem, you get the splash screen and everything is working up to that point which tells me the motherboard is fine.
Jul 07, 2012 | IBM ThinkCentre M51 PC Desktop
Thinkcentrre 8143 can't change bios
The f10 is usually the save and exit or exit options key. Your particular version of BIOS should tell you in one corner of the screen.
May 17, 2012 | IBM ThinkCentre® M51 (8143-WVS) PC Desktop
Where do I get the driver download for the system speaker for the M51 8143 39U?
go to google type in the make and model of your pc and sound card up grade it will take you to sites to download
Jul 20, 2011 | IBM Lenovo ThinkCentre® M51 (814339U) PC...
I jst bought used IBM 8183 Thinkcentre every time
You will need to install Windows. If you have an install disk, insert the disk into the optical drive and restart the computer. Go into BIOS and select "Boot from CD/DVD". Follow the install instructions on screen.
Apr 12, 2011 | IBM Computers & Internet
My ibm thinkcentre m51---8143 will not work with f9 or f10 save and exit settings
If you are talking about bios settings, is your cmos battery dead?
Aug 04, 2010 | IBM ThinkCentre M51 PC Desktop
I have an ThinkCentre M51 8143-14U and i wish to upgrade to a better power supply for a graphics card. But i don't which to buy because of different dimensions sizes and cords. im after anything over 500W.
There are only two different sizes of power supply commonly used that I know of and all power connections are the same as well.
I would suggest a reputable power supply that has specs for each "rail" in amperes not just 500w as there are many pwr supplies that do not "cut the mustard". You can research these in www.tomshardware.co.uk
Mar 29, 2010 | IBM ThinkCentre M51 PC Desktop
IBM ThinkCentre M51 PC Desktop Logo
4,362 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
