Question about Boating
My 84 merc 40h will not pull up any speed when you put the throttle down. Its on a 84 bass tracker 16 foot flat bottom boat. It has fuel delivery problems but i am putting a fuel pump kit in today. Do you think that has anything to do with it or do you think it is electric problem?
  • Dean
    Dean May 11, 2010
    Yes most likely fuel delivery, or carburettor related. Put in new fuel pump, then test... If still no go, time to strip the carburettor and give it a good cleanout, including the high speed jet needles.
  • Frank
    Frank May 11, 2010
    if the motor run without any problem beside lack of power, the fuel delivery correction should be just that.
    Champion:
  • 207 Answers
Change the plugs first if not or u have already then its probally your power pack
Posted on Jun 27, 2009
Car randomly start choking, slow down even with the foot down. revs go up but not speed, gets jumpy when pull over. has new battery, fuel pump spark plugs muffler and catalic converter.
not enough air
too much fuel delivery
or bad valve /cylinder compressions
lots more to look at
the car should have fault codes to guide you
EFI
air filter.... Maf ..throttle body
depending age of car
coil. /electronic distribuor. idle control solenoid
crank angle sensor
May 19, 2016 | Cars & Trucks
I have a 03 Sun Tracker pontoon & Merc 60 my throttle trim will lower motor but not raise it.It works fine from motor ,up & down okAlso just had voltage reg. replaced and tach stopped working .Help
Time to just go threw all the wiring. You have a boat. It's on the water or not. On the water electrolysis kicks in 1000%. On land corrosion set in. Check and clean the wire plugs, replace if necessary. Replace ground point connectors. Add wire if necessary. Just a note. When I do boats, I solder all connections and use silicone shrink wrap on the wires.
Jul 01, 2015 | Boating
115hp mercury outboard
there sould be a rubber primer bulb in the fuel line . squeeze it several times till firm.
Jul 04, 2014 | Boating
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
My bass boat sat for about 8 months. I had it on the water this weekend and it was not idling well and had trouble starting. Once started, the boat ran well when i was in the throttle. I ran the old gas...
SOUNDS LIKE THE CARB LOW SPEED JETS ARE CLOGGED , THANKS TO THIS PITIFUL GAS WE GET TODAY ,I USE A ADDITIVE CALLED SEA FOAM IT WORKS GREAT JUST ADD TO FUEL EVEN WORKS FOR WINTER SET UP TOO
HOPE THIS HELPS
Aug 10, 2010 | Light Outboard Motor Boat Bass Fishing...
Boat does not plane
you could try a lower pitched prop.2" would up the revs by 400 revs.,which would up the revs ,but give you more low down thrust,and/or tucking the motor under more[if you have electric trim/tilt].thats a big boat and fair bit of weight for a 40hp..my 40hp merc is on a 13ft saracen,and with two of us it takes a while to get gooing.so i bought a ProPulse prop,with adjustable pitch.been god to try different pitches
Jul 10, 2010 | Light Outboard Motor Boat Bass Fishing...
Our 40 Merc Won't open all the way up under load.
A couple of possibilities are the spark advance and the fuel line. Carburetors can do it as well as a clogged screen on the fuel pump. So can a bad coil.
Look for electrical parts under the flywheel area of the motor. When you move the throttle there should be movement of the stator to advance the spark. Check for binding wires or disconnected linkage.
See if the spark is jumping strong to the plugs for coil strength or have it tested.
Check fuel pump screen and diaphram.
Before messing with carbs-disconnect cables for throttle on boat. Work by hand directly at motor. You may have cables restricting movement.
Thats about all I can think of. Let us know of outcome.
Aug 13, 2009 | Light Outboard Motor Boat Bass Fishing...
Merc 75 4 stroke turns over but wont run
carbs, are gummed up. Pull the carbs and clean em, you'll be up and running in no time. The gas they sell now days, it don't take long for it to varnish.
Jul 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Motor fires off great and run good but at full speed after 15 mins it dies and won't start after 10mins it will start but at hight speed only after i get it going run good at 1/2 speed
What Year? Have the coils checked, they are located under the flywheel, some have been known to act up over time due to heat because of age. They time between dieing and restart souns like they had time to cool off until overheating again
Apr 17, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
109 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
