Question about HP Color LaserJet 2600n Printer
Magenta cartridge no print out
Can you pls. help me about my printer problem.. the magenta cartridge dosen't have print out. but the rest of the cartridges is working.. how could i fix it..??
  • 64 Answers
Firstly check the chip on the cartridge doesnt have any scratches or dents/ bits missing ect and give it a wipe with a dry lint free cloth. if you still get the same you may need to shake the cartridge slightly. hold by the handles and GENTLY move as if your holding a piece of paper wafting a fire. Hope this helps Cops
Posted on Oct 08, 2007
Magenta light flashing
Check your lights , this printer has a user replaceable print head as well as the ink cartridge
Nov 17, 2013 | HP Officejet Pro K5400 All-In-One InkJet...
My paper become polluted by color printing
Hi there!The problem is in you magenta toner cartridge.It happens when a cartridge is refilled or it has damaged PCR.The best way to fix this is by changing the magenta toner.If you have other questions pls feel free to ask!
Dec 18, 2012 | Office Equipment & Supplies
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
How can I remove from my stylus sx115 the ink
Found this on the web. You can download the entire
manual if you like. If you find this helpful, pls rate me.
Mar 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon i9900 isn't printing photo magenta
Use denatured alcohol to soak the print head. Then use suction to draw the alcohol back thru to the foam ports where the ink cartridges rest. Continue until the alcohol runs clear. Then use water and then repeat with alcohol. Allow to dry and re-install in printer. Use new ink cartridges when re-starting printing.
Dec 31, 2008 | Canon i9900 InkJet Photo Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
HP Color LaserJet 2600n Printer Logo
43 people viewed this question
Ben Johnson
