Question about Kenmore 24 in. 16152 Built-in Dishwasher
Upper rack spinning device fails to aquire water and does not spin
Kenmore dishwasher 587-16152400 The spinner-rinse mechanisim for the upper rack does not spin or rinse or fill with water. It appears that there should be some sort of funnel that would allow the water to route from the top of the dishwasher into this spinning device - or maybe it works in a different way? No water seems to make it into the round plastic shaft that is in the middle of the upper rack, so therefore no water goes into the spinner and it fails to spin and therefore dishes in the upper rack do not get washed
  • 423 Answers
Jeff, When a dishwasher acts like this, the most common problem is a blockage in the sump area, underneath the lower spray arm. Removing any/all filter and covers down there (screws will need to be removed) and inspecting with a flashlight, remove all debris (watch out for broken glass!)  Also, inspect the "impeller" that is turned by the wash motor for damage or being loose while you are down there.  Reassemble and test out.
If problems remain, the next most common problem is a failed wash motor.  It is common over the years for it to weaken as it heads towards total failure.  These motors, when they fail, can not be repaired, rather they must be replaced.
Please post back with what you find, OK?
Posted on Apr 14, 2009
Dishes in top rack do not clean. both upper spinners do not appear to be spinning when running. They spin by hand but not spin on their own during cycle.
When my wife started complaining about her dishwasher not getting the top rackclean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 18, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
The top spinner/cleaner dish sprayer thing isn't spinning or spraying water on to the dishes on the top shelf. The rest of the dishwasher works. Any suggestions on how to fix?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
DISHES ON TOP RACK ARE NOT GETTING CLEAN TOP SPINNER NOT SPINNING POSSIBLY NOT ENOUGH WATER PRESSURE?
It would help if you provided the make and model of the dishwasher.
Most likely cause of not getting enough water pressure to top rack is the water diverter may be faulty.
Depending on the model - it is a small ball floating in a vertical channel which alternately opens and closes the bottom and top water inlets to the spray arms. Check part at Repair Clinic after selecting make & model of your dishwasher.
Jun 17, 2010 | Kenmore Dishwashers
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
Kenmore Dishwasher Holding Water
lost your tube that supplies water to upper spin rack? look in your strainer
Apr 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 16152 Built-in Dishwasher Logo
460 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
