Question about ASUS P4S800-MX Motherboard
Bios update I try downloading the bios update driver, for asus p4s800-mx, and copy the files on a disk, but when I used the EZ flash, still no update happened, maybe theres something wrong with the bios update driver, any one ca help me , where can I find the latest bios update driver?
  • 173 Answers
Re: bios update
Posted on Oct 10, 2007
  • 625 Answers
Re: bios update
Make sure your bios is an eprom. people download bios upgrades only to find their bios is not a flash bios. that is it doesn't have the infrared source to physically "flash" the chip.
Posted on Sep 13, 2007
0 characters
3 Points
I've AMD Athlon 64 bit processor 2800+ Motherboard Asus K8S-MX Series SiS 760 Fx series chipset BIOS version: 08.00.11 How can I save my current bios and update bios??
you must plug in your pc with ups
do step by step from internet and alwayas choice last date
for download =
1st thing you'll need to do is go to the motherboard manufacturer's website & download the new BIOS file & the flashing program. These 2 files will have to be copied to a bootable floppy, then you'll have to boot off it & do the update from DOS. The motherboard website should have a detailed explanation on how to perform a flash...print out the instructions & follow them exactly & you should have no problem
Nov 12, 2010 | ASUS K8S-MX Motherboard
Bios asus P5S800VM,rom
Try Updating your System Bios from
Version 1023
Update Procedure:-
1. Copy the ROM file in a pen drive
2.connect the Pen drive to the usb port of your Motherboard
3. Restart your m/c and press Del Key and Enter Setup
4. Go to
ASUS EZ Flash and update the Bios.
Jun 06, 2010 | ASUS P5S800-VM Motherboard
Can download the complete driver of ASUS P4S800-MX free
  • Go to
  • Click on "Download Product BIOS, Drivers, User Manuals and Utilities here"
  • use the auto "ASUS Navigation wizard" or enter machine details in "General Download"
Apr 23, 2010 | ASUS P4S800-MX Motherboard
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website ( to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
P4S800-MX Bios update
It could be that you have disabled BIOS flashing. Go to BIOS and look for the option and enable it
Sep 10, 2008 | ASUS P4S800-MX Motherboard
Bios update problems P4S800-MX
An .exe file isn't a .rom file. You downloaded the flash program (the program used to flash new data to the ROM), you didn't download the flash data. Look on the site again, or look to see if there's another file - P4S800MX.ROM - to extract.
Where you can find a file for a BIOS?
I need a file of BIOS to put it in the A: device.
But I don't know how I can get it.
Aug 27, 2008 | Intel Motherboard
Upgade motherboard
What problem is it that you are having?
If you want to upgrade you're CPU here is the Asus link for supported CPU's P4S800-MX motherboard.
To the right of the list is the bios file that must be used to support the CPU.
If you need instruction on how to replace a CPU just let me know.
Jul 21, 2008 | ASUS P4S800-MX Motherboard
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
ASUS P4S800-MX Motherboard Logo
1,149 people viewed this question
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
