Question about D-Link DI-634M Wireless Router (DI634M)
How to reset the d-link di-634m wireless router
    President:
  • 1,138 Answers
Go to this link to to reset your d-link 634m manually: http://www.retrevo.com/pdf/426bh043/6/Hardware+Overview#q=D-link+DI-634M
Posted on May 16, 2010
Benimur
  • 6966 Answers
SOURCE: My D-Link DI-634M wireless Router never worked
Hi, Like most router products, the reset is at the rear near the power jack connector. You have to use a straightened metal paper clip to press on the hole to access the small push button underneath. Do this with the power connected. Press for a couple of seconds or till the leds blink. Once done, the unit will be set to factory default settings and you will have to configure it again. If this does not work, perhaps you have tried to update the firmware which: a. did not finish; b. was not successful or c; got corrupted. The only recourse for a router with faulty firmware is get RMA & replacement from D-Link. Post back should you need additional information. Good luck and kind regards.
Posted on Aug 26, 2007
Joed911
  • 4338 Answers
SOURCE: DLINK DI-634M WIRELESS ROUTER USED AS A REPEATER?
No. Here is the help guide:
http://support.dlink.com/Emulators/di634m/help_men.html
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 19, 2008
  • 82 Answers
SOURCE: connecting D-Link DI-634M to HughesNet HN9000
I hate it when ISPs give you devices that dictate how your network has to be setup. They should just give you a modem which give a public IP to whatever connects to it.
For this to work you have to connect the cable from the hughes box to your router on one of the four regular jacks on the back NOT the internet/wan jack you would normally use.
Set the IP of the Dlink to 192.168.0.254
Subnet mask 255.255.255.0
default GW 192.168.0.1
This SHOULD allow the router to act like a switch. I have a linksys that has an option to make it function as an access point , which is what you need for this modem, but I dont see any option for the d link you have to do that.
Hughes have a knowledgebase which may be of some use to you.
Here
Posted on Mar 05, 2009
SOURCE: what is the d-link part number for power adapter
what is the d-link part number for power adapter for D-link Di-634M router? How can I get this?
Posted on Oct 17, 2009
BearWeb
  • 357 Answers
SOURCE: I had to reset my
When you log in to the router, in the first tab (You should already be here by default after login), click on "Wireless" and use the following settings for greatest security:
1) SSID - Set an SSID, this can be any phrase that you like.
2) SSID Broadcast - Here you can use either of the settings. If you enable, any device will be able to detect the unit and then they just need to type your WEP key to gain access. If you disable, nobody, including yourself will be able to find the network as the SSID is hidden, instead your network will come up as "Other Network", you will then need to enter the SSID and WEP key to gain access.
3) Security mode - WEP
4) Authentication - Shared Key
5) WEP Encryption - Choose 64 bit
6) WEP Key 1 - Set a phrase that you will easily remember as you will need to use this on all the devices that connect to your network.
7) WPA Mode - WPA2
8) Cipher Type - TKIP
9) Passphrase - Type a passphrase and then confirm it
That's it!
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Posted on Aug 20, 2010
Can a DLINK DI-634M WIRELESS ROUTER BE USED AS A REPEATER?
No, sadly it doesn't support WDS (Wireless Distribution System), most of the time I prefer Linksys routers since are easy to configure and WDS capable, if you get two of them I'm sure you can establish a WDS network easily.
May 17, 2011 | D-Link DI-634M Wireless Router (DI634M)
Can I use a D-Link DI-634M as a repeater? how?
Sorry, no, the DI-634M does not have the repeating function.
Mar 06, 2011 | D-Link DI-634M Wireless Router (DI634M)
How do u access ur wireless setup instructions for d-link routers on internet explorer?
Heres a link to the support site http://www.dlink.co.uk/cs/Satellite?c=TechSupport_C&childpagename=DLinkEurope-GB/DLTechProduct&cid=1197319378173&p=1197318962293&packedargs=locale%3D1195806691854&pagename=DLinkEurope-GB/DLWrapper
Quick setup from here ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_qig_100.pdf user manual from here ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_manual_100.pdf
Connect the PC to the router by cable then to log into the router using the default settings
  • Open the Web browser.
  • Type in the IP Address of the Router http://192.168.0.1).
  • Type admin in the User Name field.
  • Leave the Password blank.
  • Click OK.
now goto the wireless settings on the router to see the settings being used
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 01, 2010 | D-Link DI-634M Wireless Router (DI634M)
Port forwarding of Router D-Link DI-634M
Yes this router has a port forwarding capability, to know about that and how it is done from this router check this link.
http://portforward.com/english/routers/port_forwarding/Dlink/DI-634M/DI-634Mindex.htm
Feb 23, 2010 | D-Link DI-634M Wireless Router (DI634M)
I lost my D Link DI 634M passphrase and security key. How can I recover or reset it?
Link up with LAN
On your internet, type in,
192.168.1.1
now type in the security key.
it should be 1234.
Dec 31, 2009 | D-Link DI-634M Wireless Router (DI634M)
Conection wireless dlink di-634m with notebook windows vista no work !! help !
Make sure you have the ipx and spx protocol install on the wireless adapter.
Nov 14, 2009 | D-Link DI-634M Wireless Router (DI634M)
Can I use a D-Link DI 634M as an access point?
Sure you can! As you can with any wireless router pretty much.
1. Assign the new router (AP) to an IP on your subnet that's not your existing router's IP... i.e. 192.168.0.2
2. Disable the DHCP server on the "AP"
3. Create a new wireless network on the "AP"
4. Plug your existing network/router into a LAN port
DO NOT USE THE WAN PORT
Voila! You have an access point!
Jun 21, 2009 | D-Link DI-634M Wireless Router (DI634M)
What is the d-link part number for power adapter for D-link Di-634M router?
Mar 28, 2009 | D-Link DI-634M Wireless Router (DI634M)
Thanks, Joe
Nov 19, 2008 | D-Link DI-634M Wireless Router (DI634M)
D-Link DI-634M Wireless Router (DI634M) Logo
1,412 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
