Problem for Washing Machines
Generic problem for all Washing Machines
Bosch washing machine
clasixx 1000
door seal
removed first spring clip from front.. where is second and how to remove have taken top off cant see.
help
got new seal ready to fit.. dont want to pay £65.00 call out to plumber to fix!
Same Problem
Jan 05, 2008
-   similar prob, cant get the seal back on - i understand about the spring ring thing but i cant get the seal itself on properly first - any tips or tricks - its a zanussi f1045w
cheers-
barry_1176 Dec 18, 2007
-   My front Loading GE washer leaks water because of the seal between the door and washer. The spring that was in it came off. What do I do to fix this?-   Guest
Best Solution
posted on Sep 13, 2007
Rank: Guru
Rating: 86%, 378 votes
i am recently retired appliance engineer of 20 years, the rear door seal clamp is generally nowadays a large thin spring that is slightly hidden by the concrete weights at the front of the drum, if thats the case the door seal will just come off with a good firm pull round the drum edge, fitting as a reverse of removal, place the door seal in the groove so it fits like it should, then stretch the spring and fit that into the outer groove round the lip of the door seal at the drum end, once that is done fit the seal on the front panel lip, then replace that clamp, check all is fitted securely before running machine
its one of those jobs that hard to explain how to do it, hope i have helped a bit, its easier to work through the front door opening than from above?
if i have please rate me
thank you
Was this helpful?1 person thought this was helpful
Solution #2
Rank: Guru
Rating: 86%, 126 votes
The door seal seals between the glass door and the drum, so the inner clip is attached to the drum. If you have the lid off you should be able to see it but it may be hidden under the rubber edge of the seal itself. Run your fingers from the edge of the seal where it attaches to the glass door inwards towards the drum and you should feel the metal clip. It will be a very big hose clip style.
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
need to purchase a new front load washer to replace my 7 year old frigidaire
Whirlpool Cabrio WTW6300 worth the $$?
Control Panel is locked on Kenmore Elite Washing Machine. HE3t
When my Kenmore 70 series washing machine was spinning I heard a loud bang and then there was a...
(More)
When my Kenmore 70 series washing machine was spinning I heard a loud bang and then there was a cloud of oily smelling smoke coming from the bottom of the machine. It seems to work ok, but I don't want to chance more damage or something worse like a fire. Could this have been a capacitor that blew up?
I have a torn bellow on a Maytag Epic Z (Model #MHWZ400TQ00) and need step by step instructions on...
(More)
I have a torn bellow on a Maytag Epic Z (Model #MHWZ400TQ00) and need step by step instructions on how to instal the new bellow myself. thanks.
