Question about Nintendo Wii Console
Unable to play my brand new wii fit
All connected correctly to tv. (2yr old samsung) But will not work as don't know what channel to go on. Have dvd player, which when I insert disc into film just starts to play. Have looked at tv instructions for game mode, followed them but still no luck. Can you please advise? According to wii fit info, as soon as disc is inserted into consul,game will appear on screen. Help.
I was just being really thick!! Eventually I found the right button on the remote and there it was on the screen. Thanks anyway though, and I know where to find you again. Sure I will!
Posted on Apr 15, 2009
We are trying to set up wii-through the dvr to play on Sharp LC-PD50U-unable to get it to work.
Connect the Wii directly to the TV either using the HDMI cable or the Hi def cable(5 RCA connectors) that come with the Wii. Then select the input number on the TV to get a picture .
Dec 25, 2012 | Sharp Aquos LC-PD50U 50 in. Plasma...
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
We have a Wii that plays through a Magnavox MWR10D6 DVD Recorder. Currently we can play a DVD in the recorder and the Wii activated and we can hear it working but it will not show on the TV screen. The...
Assuming that you plugged the video cable from the Wii into the "VIDEO IN" connections on the Magnavox, you need to do two things:
1) go into SETUP and make sure the inputs are set to regular/composite, NOT S-Video
2) use channel -/+ on the Maxnavox remote to select the correct input
Feb 18, 2011 | Philips Magnavox MWR10D6 DVD Recorder
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
I can watch movies on my samsung LNT3242HX/XAA but I am unable to see or hear anything if i hook it up to cable, i know something needs to be replaced but not sure what? the tuner maybe?? ;p
1. Make sure you have connected the cable to the correct input on the set.
2. Access the User Menu and do a "Scan for DIGITAL" channels.
That should do it...
Jun 13, 2010 | Samsung LN-T4065F Television
I need to know what channel to operate my wii on. I have a toshiba tv that is about 8 years old.
Try changing the TV inputs to VIDEO or AUX, using the remote or a button on your TV. If there is not a way to connect the Wii to the TV using the 3-cable system (Yellow, Red and White), then you might have to use a VCR or DVD player to plug the 3 cables into and then transmit the audio and video from the Wii using the regular cable line of VCR or DVD Player on TV channels 3 or 4. If your Wii has a regular TV Cable jack on the back, connect that to the jack on the back of you TV and select channel 3 or 4.
Jan 05, 2010 | Nintendo Wii Console
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
May 30, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Old Sony Triniton KV-M2 with no instructions how to tune in Wii?
HI,TV MUST HAVE A SCRAT SCOKET IN BACK?,OR THE WI WOULD WORK ON AV SETTING ON SET ,OR GO THROUGH CHANNELS WITH WI ON AND IT SHOULD WORK,THANKS
Jan 02, 2009 | Televison & Video
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
Nintendo Wii Console Logo
161 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
