Question about Hotpoint Aquarius WF210 Front Load Washer
Flashing on/off and rinse hold lights
These lights are flashing on my washer i have been told tacho prob or motor jammed the motor is free and the tacho has not come off i have checked all the wiring from the motor through the plug and down to the module all seems ok can any one help please
  • 1 more comment
  • Anonymous Sep 14, 2007
    hi there the pump runs fine nothing clogging it when i put it on a wash cycle the machine fills with water then pumps it out while spinning with the on/off lights flashing and rinse hold to stop it i have to unplug it from the wall i am told its a tach / motor fault but all the wiring checks out ok from the motor to the module
    hi there thanks for your help when i put it onto a wash programme the machine fills then pumps out straight away with the motor on a spin i have not got the motor on the machine its on the floor by the machine with no belt or drum connected as i have been trying diffrent things and cant be bothered to keep putting it on and off lol how the problem first came up was i replaced the bearings on the drum as they had failed i got it all put back together ok and thats when this problem started
    yes i built it back up thinking the job was done it was when i tested it i came across this problem i have cheacked all the cables from the motor through the plug and down to the module all is fine there i even get a ressistance through the tacho when i turn the motor im guessing i may have a module fault i cant think of anything else i could put the motor back on the machine to see if it is a drum sensing issue other than that i cant think of anything else i must thank you for all your advice
    Sergeant:
  • 212 Answers
If it is not rinsing it may have a small piece of clothing stuck in the waste pipe or pump. Remove the rubber hose from the waste pump and check inside the hose and make sure the pump spins freely.
Posted on Sep 13, 2007
  • Bobby G
    Bobby G Sep 14, 2007
    These lights flashing are a sign of a error in the program. Are you saying it doesn't wash? Is it very noisy when it spins? and does it take water in then rinse it out straight away? Can you see the drum move about more than normal? The drum may be out of balance when clothes are in it and the module will then simply go to rinse mode without washing. There are at least two drum mountings on the side of the drum which may be loose or even broken, make sure these are OK. You will see them if you take the lid off and look downwards towards the drum.
  • Bobby G
    If the motor is not turning the drum this can cause program issues because the sensors are not sensing drum movement so they may switch on the waste pump and rinse to avoid water remaining in the drum without it spinning.
    I guess you did initially build it back up after replacing the drum bearings! If this is when the problem started check that you have all connections attached.
SOURCE:
Programme won't move on - rinses flashing and programme won't continue
Hi dear. Regarding your information, I would say 3 factors play up with it.
1- Tacho generator or it's plug faulty on motor
2- Motor Carbon brushes worn out or
3- Power/control unit faulty.
I can advised to contact your local Miele center to diagnose your machine.Thanks.
Apr 17, 2016 | Miele 300 Front Load Washer
Aquarius wml560g f2 f4 and door lock lights on. nothing happens.
f2 is motor tacho detached / motor jamed f4 pressure switch jammed on empty if there is still water in your washer its proberly the filter blocked or the pressure chamber the motor tacho registed the fault on to the computer because it could not turn at full speed the fault would indecate to me that if you clean your blockage in the pump / filter /presure chamber also if you have your washer drain hose connected under your sink take that of and check also
Nov 24, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
WHAT DOES F 02 FAULT MEAN ON THE AQUARIUS W740
"F02 = Motor jammed or tacho detached".
Check the motor hasn't jammed up somehow, or that the small tacho coil (the thing that detects the speed of the motor) on the end of the motor hasn't dropped off (tip the machine back and it's in between the brushes - it should be held in place with a clip. If it's hanging loose it's the fault)
This fault code basically means the PCB cannot detect any impulses from the tacho coil on the motor, so the main implication is that the motor is just not running. However, because other fault codes cover most of the other motor faults, the PCB thinks the motor may be physically jammed. That is, as far as the PCB is concerned, it is supplying the motor with power, but it can't detect the motor is running.
Aug 30, 2011 | Hotpoint Aquarius WF215 Front Load Washer
The buzzer sounds and the rinses indicator light flashes and the programme sequence display " - - - " appears in the display. This occurs at the end of all programmes just as it starts to spin.
Hi - I will tell you whats wrong with the machine, but you will need to get someone familiar with Miele equipment to fix it for you.
On this particular series - Rinse LED flashing means 3 - 4 things could be wrong with the washer.
Tacho - generator is faulty
Drive fault - electrical problem
Motor - has issues with starting
Blockage - drains - drive unit
Restrictions - of the drum turning.
Electronics - may be a component with an intermittent failure/decay.
It would be either one of the above or a combination of 1 or the other...
Jun 20, 2011 | Miele W435WPS Front Load Washer
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
F-02washer dryer problem
F02 means the motor is stuck or jammed, check the motor , tacho and module. For more Hotpoint, Creda and Indesit error codes use this link
Mar 18, 2010 | Hotpoint Aquarius WD640 Front Load...
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint ultima wt721 error code fo2 showing! will not work properly!
Error code F02 means the motor has jammed, and or the tacho is loose or broken. .Check the motor hasn't jammed up somehow, or that the small tacho coil on the end of the motor hasn't dropped off (tip the machine back and it's in between the brushes - it should be held in place with a clip. If it's hanging loose it's the fault)
This fault code basically means the PCB cannot detect any impulses from the tacho coil on the motor, so the main implication is that the motor is just not running. However, because other fault codes cover most of the other motor faults, the PCB thinks the motor may be physically jammed. That is, as far as the PCB is concerned, it is supplying the motor with power, but it can't detect the motor is running. This fault is not caused by worn carbon brushes because on these washing machines, an open circuit on the motor causes the washing machine to do nothing at all. It would not fill, or empty (as well as the motor wouldn't run) although the indicator lights would work.
Nov 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
I'm after some error codes please guys, It's flashing 2(Reduces Creases) & 4(Time Saver) I've been told that these 'do' mean something, but can I find out what it is....no Any help would be really...
List of the Error Codes I found on another site. I'm getting f04 light 2 (the "wash" light). Looks like you've got the opposite problem with your pressure switch stuck on full (f05).
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Sep 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius WF210 Front Load Washer Logo
259 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
