Question about Dell Dimension 4600 PC Desktop
Upgrading memory I have a dell demension model 4600 with only 256 of ddr ram. I bought a 1 gig dimm same speed and type pc 3200 and the bios takes an error. as follows. OS Install mode enabled. Amount of memory limited to 256m. Any help would be appreciated. Thanks, Dave.
  • sp2superd Apr 16, 2009
    I ran it solo and that did not work either. The max on this us supposed to be 4 gig. Checked the bios and nothing there to help. You can go lower but not higher for some reason. I even updated the bios from dell and still no change????? thanks for you answer....
    I also heard that Dell uses special dimms that you can only get from them is that true.
    Problem Solver:
Hi If you go to www.crucial.com they will scan your pc & tell you what rams youhave & what you need. then buy from wherever. hope this helps blue51
Posted on Apr 15, 2009
  • 1,959 Answers
Your machine's maximum is 1GB. By installing a 1GB chip on top of your 256MB chip, you've overloaded your motherboards capability. Remove the 256 chip and reboot. Your machine will then recognize the 1GB of RAM with no error.
Posted on Apr 14, 2009
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Tried to upgrade my ram modules from 512 to 2gb. also installed a new video card (for a moment... but then removed it when the problem occured). now when i power up, i get a steady...
    what type of ram did you upgrade with it should have been DDR and keep the same brand/type of ram modules the same check the ram sockets make sure they are clean and the ram is securely seated The ram modules should have either of these 2 the same 1 GB 184-pin DIMM DDR PC 2700 memory module 1 GB 184-pin DIMM DDR PC 3200 memory module
    Jul 01, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
    I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
    Hi this model sopport 2Gig Memory Ram.
    RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
    Please check in to your Bios system maybe share memory Video or capacity is setting
    Nov 03, 2010 | Dell Dimension B110 PC Desktop
    # of RAM slots
    There are two models for this type of desktop, the first having only two DIMM slots, but that takes PC2700 Ram, you have stated that yours takes PC3200 which would make it the second model in which case your model has (4) DIMM slots, each slot is capable of holding a 1 GB stick of ram for a total of 4 GB. Your RAM specification is DDR PC-3200
    Jan 12, 2010 | Computers & Internet
    Want to upgrade from 512ddram to at leat 1G. How would i know that my new purchase would be compatible with my set. I'm using a pentium d 820 on foxconn 865G7mf-sh motherboard. Tnx.
    http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000166
    That page has all the specs.
    It says that you can use Dual Channel 400 / 333MHz DDR x2 DIMMs, Max 2GB
    That can be bought at bestbuy for under 45 bux!
    Kingston Technology Kingston ValueRAM - Memory - 1 GB - DIMM 184-pin - DDR - 333 MHz / PC2700 - 2.5 V KVR333/1GR $44.99
    http://bestbuy.upgradebase.com/
    Dec 16, 2008 | Computers & Internet
    Increasing Memory Ram
    According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
    Look here for more information.
    http://www.crucial.com/store/listparts.aspx?model=MS-6390
    Aug 28, 2008 | Intel Motherboard
    I want to upgrade Ram
    yes there are different types of ram available but since u have a ddr 1 type of ram ddr2 wont match in ur maotherboard.and also do try to get the same type of ram available presently so u dont have problem with the clock speed.
    May 12, 2008 | ASUS P5S800-VM Motherboard
    Ram memory upgrade
    1 gig is the max. Get two sticks of 512mb kingston. If you go to kingston.com you will see ways on how to find the optimized RAM for your computer. If i am correct here are the specs for the ram that you need. 512MB-DDR333 PC2700, 184p DIMM, 2.5v, Sync, CL=2.5
    Feb 25, 2008 | Areca ARC-1210 Serial ATA Controller
    Type of memory for e210882 motherboard
    the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
    hope this helps.
    thanks.
    Feb 05, 2008 | Dell (E210882) Motherboard
    Dell Dimension 4600 PC Desktop Logo
    177 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
