Question about Apex Digital PF2720 27" TV
Question regarding my Apex PF2720 TV: One channel
Question regarding my Apex PF2720 TV: One channel (that I've seen so far) has a black box almost covering the screen that comes on about 5 second after I switch to that channel. Inside the box, at the top, are these numbers: <008A5EA5> [D7E2]. If I press any key on the remote, the box goes away but reappears in a few seconds. I've tried reprogramming the channels, but don't know what else to do. Thought it was cable, but tried connected another tv to that same cable & it doesn't do it. Help!
  • 67 Answers
Check your close captioning settings make sure they are off you probably are accessing an unused cc chanel
Posted on Apr 14, 2009
Take your TV remote (not the one that comcast gave)... look for captioning settings.. turn it off
Posted on Jun 22, 2009
I have an Apex AT2402 TV and bought a Magnavox DTV Digital to Analog Converter box , and I only got 3 channels after the channel search. I tried it 2 more times with 2 different antennas I had and it
I use an RCA box. Never had any problem.
How far away are the television broadcast antennas?
If they are farther than 40 miles, that may be the problem.
Hope this helps
Jan 25, 2015 | Apex Digital AT2402 24" TV
Apex TV LD3288T can't find channels
Have you set it on cable, it may be set for antenna.
Oct 12, 2014 | Apex Digital Apex 32 Class 720p 60hz LCD...
Child lock came on by itself on apex pf2720
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Aug 15, 2012 | Apex Digital PF2720 27" TV
How to change a bulb in a apex pf2720 tv
I'd guess it is not a bulb issue if the audio also stopped working. Check your input source, connections and the like. Try using a different input (ie input 4 or the front AV connectors) and a different source (ie your old Nintendo instead of your DVD player).
Nov 17, 2011 | Apex Digital PF2720 27" TV
Hi, I have an Apex TV model AT2402S that has lost the audio and video, when I turn it on I only see an horizontal line in the center of the screen.How can I fix this problem?
hi ,thats a vertical ic problem and some few capacitor they need
to be replaced and verify for cracked soldering arroundthe chip.
thats should solved the problem/if you dont have experience call a tech,
regards Alan
Dec 30, 2010 | Apex Digital PF2720 27" TV
Vertical size adjustment
There is a black box appearing on about 75% of the screen. How can I remove it???
Sep 17, 2008 | Apex Digital PF2720 27" TV
Apex flat screen television model #pf2027
yes it was soo easy to fix but i offended that you want me to pay u for the answer yet u want me to give it to you for free. sorry but thanks for nothing
Mar 06, 2008 | Apex Digital PF2720 27" TV
Tv Has Big Black Box
shut off close caption. use the CC button onthe remote or go in to the menu and change close caption to CC1. this box is the close caption in TEXT(1,2) which will put on a black box whenever there is caption present.
Feb 22, 2008 | Apex Digital PF2720 27" TV
Service Mode for Apex PF2720
On a standard PU1 chassis use the following:
1. Decrease the volume to 0
2. On remote press and hold the MUTE button till the color of MUTE displayed changes color. At the same time press MENU on the front of the Tv.
CH +/- to select
Vol +/- to change value
All other chassis:
Decrease the volume to 0, Press mute and video at the same time.
Adjust the TV with menu select buttons on remote.
Exit with the power button.
Hope this helps.
Bill
Nov 25, 2007 | Apex Digital PF2720 27" TV
After 2 years of use, screen on TV went to white but sounds still works
Hi Sounds to me like the Tuner Module went out, this is something a qualified technician would have to fix.
Mar 08, 2007 | Apex Digital PF2720 27" TV
Apex Digital PF2720 27" TV Logo
524 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
