SOURCE: 95 f250 #7 fuse keeps blowing under hood what does this controll
you have a short its almost impossible to find..i would take it to a dealer
SOURCE: keeps blowing 15a efi fuse 1991 toyota pickup 2.2 re
there's a short somewhere causing that amperage to go up
SOURCE: Fuse for trailer right turn signal and brake blows intermittently
abad ground on that tail light unit could affect current load when turn and stop are used simultaneously. Although one side only is affected make sure of good grnd between trailer and tow vehicle. focust on the tail light unit in question. Replace the bulb. though rare, bulbs have been known to be the problem. If the bulb is breaking filiments ck the filiment orientation. filiments last longer in vertical orientation, where horizontal permits vibration to break the heated filiment when brake is applied.. good luck and let me know if This helped or not.
SOURCE: 97 dodge dakoata main fuse keeps blowing 140 amp fuse
Regulator in alternator obviously faulty, have it bench tested & fixed or replace alternator, and cure your problem.
SOURCE: I have a 2003 kia spectra 1.8 liter. The
Hi, there are 3 fuses the the alternator needs to charge the battery. These may be inside the car or in a box in the engine compartment. They are named IG1, ECU, and ALT. If you have trouble finding them, please get back to me.
On most of the 1981-88 model year engines covered in this information, the alternator/water pump drive belt is tensioned by a screw type tensioner, which makes precise tension adjustment easy.
