Question about Hoover Breathe Easy U5250-930 Bagged Upright Vacuum
Can't adjust floor height on my Hoover Breathe Easy vac
  • Anonymous Mar 20, 2014
    it doesnt raise or lower the vac
  • 72 Answers
On the bottom there is a smaller set of wheels in the middle check to make sure the spring is still in place
Posted on Apr 15, 2009
Hight adjuestment won't work
Lock the vac in the upright position and then tilt the unit back off the front wheels, it should move easier. If the height adjust does not work, there may be a broken part, I would recommend service by a vac shop.
Aug 23, 2014 | Hoover Company Wind Tunnel U53019 Upright...
My 1 Year Old Sebo X4 was lowering itself to hardwood floor with no air gap. Sebo Support agreed with my repair shop that a new (blue) brush roller would fix the problem by replacing the 'worn" brush (same...
No not quite. For a start, the stiff bristles on the blue roller can last a few years before requiring to be replaced.
The SEBO sensor wheel adjusts to the height required - unless of course the microchip board has been tampered with. If it hasn't been tampered with. If the central wheel is excessively dirty then it could be that the SEBO isn't lowering the height properly. However, the X series is great at cleaning hard floors in general - i it is not designed for the brush roll to fully hit the floor, thus as you suggest crushing the bristles. It is designed, as you recognise quite correctly to skid across a hard floor lightly as there is a squeegee rubber strip built in at the back of the roller bar that scoops all dirt into the central vacuum path. The front plate also lends this job. You are not being conned - however check that the rubber squeegee strip has not worn away - SEBO do sell the strips and they are easy to slide into via the press release door at the side of the brush roll.
If the SEBO has died then its a possibility that there is a microchip function that gone wrong it. Some more information would be good to know here as it could be a number of things such as the cord cables coming away at the handle.
Oct 30, 2013 | Vacuums
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Height adjustment on Hoover Windtunnel u5755-900 no longer works
On this model it is only a single slide adjustment lever. have you trie to tilt the vac backwards (lifting the wieght off the front wheels) and then slide the adjustment lever?
If there is a mechanical issue with it. take the bottom plate and roller out, and then the 2 small screws which hold the cover on underneath. you should be able to see the problem from there
Jan 10, 2009 | Hoover Vacuums
Bare floor attachment for Hoover steam vac with surge clean
According to www.vacuumpartstore.com, for model #'s F5903, 5904, 5905, 5906, 5910, 5912, 5914, and 5915, you need Hoover SteamVac Bare Floor Cleaning Attachment (old # 48417003). You can get it at www.amazon.com for $7.99.
Oct 28, 2008 | Hoover F5906-900 Upright Steam Vacuum
Rollers are to low and tearing up carpet.
unfortunatly you cant adjust the height on that type of machine, and new carpet no matter how good or expensive can shed for up to a year, the best thing would be to buy a cheap carpet rake ( not a garden rake ) that would get up all that fluff.
Sep 11, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Hoover Breathe Easy
Check that the bag has actually been installed properly.  If the plastic door lock has been broken off you may need to order a new door / bin cover from Hoover themselves. The only other way that the bag is popping off is because something may be clogged in the main dirt channel feeder leading to the bag.
Apr 24, 2008 | Hoover U5106-900 Breathe Easy Bagged...
Dyson 07
when using the hoover it doesn't seem to adjust it's height automatically i have to either put some pressure on the front plate or turn brush off which sometimes seems to work, i have checked filters renewed both the handle hose and the hose under the plate as they both had holes in, but it still hasn't improved
Jan 05, 2008 | Vacuums
Hoover Breathe Easy U5250-930 Bagged Upright Vacuum Logo
162 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
