Question about HP Computers & Internet
Nero9 is only loading to 7% after using the general clean tool m y laptop is a hp with 2g ram however my daughters is a hp with 1g ram and had no problems with loading nero9 or had no problems loading it on a xp with a 512 ram ijust dont understand it basically have tried numerous times any sugestions please with thanks biffo
T6524 won't recognize all ram
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Feb 24, 2013 | eMachines T6524 PC Desktop
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Could I use MacBook Pro 1G RAM (hynix 1GB 2Rx16 PC3-8500S-7-A1) to upgrade my T400 2G RAM to 3G?
Hello thx5,
It depends on how the 2GB in your T400 is currently configured. If the 2GB in there now is just one 2GB stick of RAM then yes you can add the other 1GB stick and then you will have 3GB of RAM installed. If your 2GB is two 1GB sticks of RAM (which is more likely to be the case) then the 1GB stick you have from your Macbook Pro isn't going to help.
Note: your laptop can handle up to 8GB of RAM via two 4GB sticks.
Hope this helps, if so please leave some good feedback. Thanks.
Feb 22, 2010 | Lenovo O O - T400 Ts P8400 1G/160 Cmb Wxp...
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
My computer will not boot up when 2 g ram
Try upgrading your Bios first, also make sure that the memory that you ar putting in your Laptop is type PC-2700. Other than this, I know that this comptuer has a 2G limit and should have no problem with it.
Sep 06, 2009 | Compaq Presario R3000 Notebook
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Is my presario v5000 using my ram upgrade
where did the ram come from? did you buy it or pull it from another computer? its possible the chip is either defective or not for your computer depending on where you got it, its also not that much of an increase so you may not notice it i would suggest getting another 1g stick because yours should take 2g 1 in each slot.
Jan 24, 2009 | HP Compaq Presario V5000Z Notebook
Toshiba laptop problem
The right memory for your laptop is
256MB Memory (PC2-4200) KTT533D2/256, PA3389U-2M25 KTOS534
512MB Memory (PC2-4200) KTT533D2/512, PA3412U-1M51, PA3412U-2M51 KTOS535
1GB Memory (PC2-4200) KTT533D2/1G, PA3411U-2M1G KTOS536
Using the wrong memory can caused motherboard failure.
Try reinserting the old one memory module.
Be sure that the memory is placed in the right way
Nov 06, 2008 | Toshiba Satellite A135-S2386 Notebook
1993 mitsibishi eclipse G1 to G2 engine swap
turbo? if you have a 1g GST or GSX, your gonna wanna swap in a early 1g 6-bolt engine.
the optimal configuration using stock 1g/2g parts would be:
  • 6-bolt w/2g pistons. compression: 1g= 7.8:1 2g= 8.5:1
  • 1g head/intake manifold
  • 1g throttlebody
  • 2g throttlebody elbow
  • 2g exhaust manifold
  • 2g o2 housing
  • 1g 14b turbo
Oct 12, 2008 | Mitsubishi Eclipse Cars & Trucks
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
