SOURCE: 2004 F150 5.4 LITRE TRUCK STALLS WHEN WARM
SOURCE: 1996 Ford Explorer engine sputters
after you replaced the fuel pump did you replace the fuel filter also check out the EGR valve and all vacuum lines especially the one behind the throttle body
SOURCE: 95 Jeep spitting and sputtering
you may have a vacume leak or air sucking you should be able to hear this sucking air in
SOURCE: 2002 VW Golf 1.9 turbo diesal won't start.
chances are your turbo pipe has come off near the back of your drivers side headlamp, where it gos into the inner wing to the intercooler. hope this helps
SOURCE: I have a 1999 Yukon,
You've triggered the anti theft security system. You will have to take it t a dealership to have the system reset so your engine will start. Regardless of what you've been told about clearing the computer codes, taking the positive cable loose is not the way to go. All you have to do is pull the fuse or fuses that go to the ecm or engine computer. That way, you don't mess wit the security system. Your radio may be locked down too. If it is, you'll have to go through a lengthy process to get the code to unlock it.
Testimonial: "Good advice"
