Question about Polaroid FLM-3732 Television
Volume gets real loud without the volume being turned up . THe volume is set on 1 and the tv sounds like it is on about 25.
    Novelist:
  • 159 Answers
The tv has an internal program build in the factory. and now is corrupted a technician is needed to replace this memory. (Call the polaroid company "customer service" department to recomend you the authorized service center in your area)
Posted on Apr 14, 2009
My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
U.S., Canada, & Puerto Rico - 1-800-305-2204
Mexico - 1-888-882-7326
daily from 7 am - 12 am CT.
Sep 04, 2013 | Dynex Televison & Video
I have a sharp 32" bought at Walmarts at the Christmas before last and the low volume is driving me nuts. In my small living room with Volume set at 60 it still is not loud. Is there a trick to get louder...
Unfortunately it seems to be a sharp thing. I have a sharp 46 inch and there are times when I find it difficult to hear. Some channels seem to work fine with the volume right around 20 - 25. Seems to be quite often though that my volume is set over 40 and still struggling to hear. Seems with my tv that there is no difference between it being set on 35 and 60. They sound the same. Surround sound is the way to go if you stick with sharp.
Jul 10, 2010 | Sharp LC-26D6U 26 in. LCD Television
Auto volume has little or no effect on loud commercials
This may not be a problem. I believe there is an audio effect used by video production houses to 'boost' the presence of an ads audio and this effect is not picked up by the electronic device's (in this case TV) volume stabilizing software. It is intentional by the makers of the ads.
A work-around could be to try different configurations on your TV's audio settings, such as just mono, or just 2channel stereo, or surround sound - on or off, increasing/decreasing bass and treble levels in different combinations.
The down-side to this is to get a comfortable, uniform level of volume across the board, you maybe sacrificing some sound quality - but, as with our eyes, our ears adjust well quickly (hence don't listen to too loud sounds) and what you may not like now, will sound ok tomorrow.
I can't tell if there is a fault or not, but this may help if you "trial" some options.
Jan 29, 2009 | LG 37LG30 37 in. LCD HDTV
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Apr 28, 2008 | Sharp 25N-M100 25" TV
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Sound Stuck on High
change the audio ic it has a short within.this will restore your set to normal dont forget to make checks in that same circuit as there might be resistors,diodes or caps that had contributed to the failure of the ic.good luck.
Aug 03, 2007 | Toshiba 19A25 19" TV
Too loud
I am assuming you do not have a "surround sound" system hooked up to your digital cable box, and that you have your TV volume turned down all the way and have not yet tried to adjust the volume on your new digital cable box. It might be worth a try to unplug your TV for about 15 seconds and try again. If the above is true and you can still not lower the volume through the cable box or the TV set, then I would have the cable people stop by to check it out.
Dec 18, 2006 | Sharp 25R-S100 25" TV
CANNOT LOWER THE SOUND
dude sounds like if you cant turn down the volume it is an issue with the set your watching it on man!!! This sounds like a trick q???? OMG Ok sorry if its not try to connect to a real tv with a volume control and then the sound will turn down!?
May 09, 2006 | GoVideo DVR4250 DVD Player/VCR
Televison & Video Logo
131 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
