Question about Sharp AR-M350U Copier
Error code h5-01
Sharp ar-m350u has error code h5-01 how do i clear
  • monizgreg Apr 14, 2009
    error code will not clear say's call for service.. guess it is time to call for service..
    President:
  • Sharp Master
  • 990 Answers
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Posted on Apr 14, 2009
Hi I have a sharp ar-m350u that has an error code l6-10 on the screen, what does this mean and how can i fix it , cheers
check the laser scanning unit LSU (black box). it may be ur polygon motor inside has a problem. check also the harnesh/connector or its board.
Jun 02, 2011 | Sharp AR-5320 Black and White Copier
Tip
F2-02 error code on Sharp AR-M350/450 and 355/455 Copiers
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
on May 17, 2010 | Sharp AR-M350U Copier
H4-01
H4-01 is an error code that the fuser temperature is too low. This can be caused by a number of things, such as the copier wasn't given enough time to warm up, or the room was cold. You can reset this code by entering simulation mode. #,*,C,* Then press 14 and copy button. Reboot the copier, and this should clear the code.
Sep 27, 2010 | Sharp AR-M350U Copier
Sharp AR-M350U Copier/Printer Error Code F2-00
clean developer unit connector .pull out , clean , then insert .
May 25, 2010 | Sharp AR-M350U Copier
Code H4-01
The problem associated with this code is related to the fuser not heating up fast enough. H codes cannot be cleared by powering off and on the unit. A service call is required.
Feb 16, 2010 | Sharp AR-M350U Copier
I have a problem with a AR-M350U. Bottom half of
charge ?
also drum earth could be a factor.
Feb 08, 2010 | Sharp AR-M350U Copier
Error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
May 07, 2009 | Sharp AR-M350U Copier
Error code l6-10 on a sharp ar-m350u
I can't find a table of Sharp error codes.
Do all documents have this problem? Then I would contact an authorized Sharp repair center.
If there's only one document that does this, it could be a corrupt or very large file that the printer can't handle. Try sending a single page of the document instead of the whole thing.
Isn't the AR-M350U a "Corporate" multifunction device? Then your vendor should be providing warranty support or service contract support for it. Check with the vendor before getting involved with another company.
Jul 18, 2008 | Sharp Computers & Internet
Sharp AR-M350U Copier Logo
507 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
