Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Epson RX425 multifunction
Problem, scanner not working I can copy and print and card read but I cant scan. Tried epson s&s loads of times no luck, got the icon cant get the function, doesnt seem to be talking to the pc. Running on Windows XP. Anyone any ideas???
  • 4 more comments
  • darcydeb Sep 20, 2007
    OK did all that and then it started to present the scanner, downloaded and then came up with an error saying it cant be downloaded. see trouble shooter which I must know word for word by now?
    Darcy
  • Classytart Nov 19, 2007
    Have uninstalled and reinstalled software three times now and no change. Error message 'Epson Scan cannot be started' and another error message saying 'scanner in use by another' which it is not. Have updated drivers on Epson site. Any other ideas? Have had this problem before but it seemed to solve itself. Am running Windows XP. Have just had memory upgrade.
  • Anonymous Feb 06, 2008
    epson scan cannot be started
  • Mike Cushing Feb 11, 2008
    Hi, I have re-installed my RX425 software following PC crash and rebuild (by a proper expert, not just me!). Have installed ll printer funcitons but it won;t install scanner function - says "could not copy files". Help!!!!!!! please!!!!!!
  • twinklebarr Mar 02, 2008
    same probas above :( very annoying as the scanner used to work perectly! will try the suggestions and see how i get on, hopefully all will be well once i reload the software.
  • luki284 Mar 03, 2008
    non riesco a collegare lo scaner e a stampere [email protected]
Just cracked it, had same prob...printer would print but wouldn't scan
lost original CD...tryed epson downloads but not the older versions...
i needed the 2.6 version
TRY THIS
http://driverscollection.com/?file_id=24466
Posted on Feb 24, 2009
Zorg dat de scanner AAN staat.
Ga naar Start -> Configuratiescherm -> Hardware -> Toevoegen.
Windows vindt de scanner en zet die in een lijst. Selecteer deze en laat de driver automatisch toevoegen. Nu zal Epson Scan de scanner ook vinden.
Posted on Jan 01, 2008
    Genius:
  • 2,985 Answers
The scanner does work on the unit then - but not through the PC that right? Uninstall all Epson software Reboot the computer and close down your internet connection. Disable your Antivirus software Reinstall all the software. Reboot the computer. Tell us how you got on.
Posted on Sep 19, 2007
  • john ash
    john ash Sep 20, 2007
    When you wroty 'down load scanner ' did you mean install the software .
    Or did the software load OK and the program not respond?
    If the program completed and still not reponded then.
    Unload all- using the unistal procedure in the
    programs file [go to Start/ Programs/Epson
    unnistall.
    When done do this -have you tried 'Regedit?
    not a problem-
    Go to Start/Run and type in - regedit- just like that- when the window opens- go to Edit/Find/ type in the field Epson RX425
    When you get lots of filels come up- Edit/Select all/ Delete.
    Then reboot ans start over.
SOURCE:
CANNOT GET EPSOM RX425 WORKING WITH WINDOWS 7
If you have already installed the driver. Go to DEVICES AND PRINTER or CONTROL PANEL then DEVICES AND PRINTERS. Right click on epson printer (RX425) then click on Printer Properties. Click on Ports tab. Check Virtual printer port for usb EPSON STYLUS RX425. Click OK. Now try to print.
Jan 24, 2010 | Epson Stylus RX425 Multifunction...
EPSON RX425.pRINTING FROM SD Memory Card
it seems the said memory card is not compatible with your printer,
Sep 01, 2008 | Epson Stylus RX425 Multifunction...
Epson RX425.Printing from SD Cards
Try to unplug the power of the printer for about 10 mins then plug it back in then try to print again.
Aug 31, 2008 | Epson Stylus RX425 Multifunction...
PRINTER EPSON RX425 NOT WORKING WINDOWS 7 ULTIMATE , IS NOT POSSIBLE FIND CORRECTLY DRIVER
Have a RX425 using with Windows7 the Easy range of software got the printer going but not the scanner! Epson contacted but said no its not supported for Win7 will need a new all in one. Not happy as RX is fully serviceable and happy with it. However I have found that downloading Epson Scan for Vista has worked .... who needs experts :-)
Nov 16, 2009 | Epson Stylus RX425 Multifunction...
EPSON RX425 RED INK LIGHT STAYING ON
Try to find "EPSON RX425 Resetter Software" at google
Sep 06, 2009 | Epson Stylus RX425 Multifunction...
Button for paper feed on Epson rx425
Please put a blank document inside the scanner and do a standalone copy.
Apr 27, 2009 | Epson Stylus RX425 Multifunction...
Microsft Vista doesn't support 4990 negaives scanning
trash and reinstall the epson scan software and download latest driver for your devices use this link support.epson.com and download drivers for win vista.
Apr 01, 2008 | Epson Stylus RX425 Multifunction...
Epson stylus PHOTO RX425
Epson has software called "Epson smart panel" and you can select scan from the list of operations.
Turn your scanner on, (windows OS) click on "start" then click on "all programs", look for epson smart panel in programs list, click and let panel load, then select scan.
It will take some time for the scanner to warm and scan, so be patient, after it is scanned your options are to print, or save. If you save, be sure you know where its filed or "tell" it where to save, I recommend creating a new folder before in "your pictures" titled "scans" . Usually after you do this, it will save it there by default.
Dec 09, 2007 | Epson Stylus RX425 Multifunction...
Reading SD card
The camera slots are on the left side. Read your manual does it take SD cards?
Nov 23, 2007 | Epson Stylus RX425 Multifunction...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
457 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
