Question about Wells F-49 21148 Deep Fryer
Fryer isn't turning on. tried reseting. still no luck
Tried to turn on deep fryer but doesn't kick on. tried resetting it still no luck. i' thinking the heating element. could there be anything else?
    Novelist:
  • 125 Answers
Hello. Here is a wiring diagram for your unit:
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20Wir%20Diag/307298.pdf
Check to see that the thermostat clicks at or about just above on, try again the reset, sometimes it is hard to push in all the way. If that does not correct the problem, make sure your power is on, do any indicators light? It could be as simple as a burnt of wire, you will need to check the resistance of the parts to tell any more, thermostat, and hi-limit should read closed (zero). The element should read 4 to 15 ohms each, there are 3 in the tube. The relay coil should be anywhere from 200 to 1200 ohms, the contacts open. I have seen broken wires in the pivot elbow where power comes up the the element head.
Hope that helped, and thank you.
If you need more help, "ask me"
Posted on Apr 19, 2009
Deep fryer won't melt. or warm up the oil
Faulty switch or heating element replace the faulty part if possible or replace the fryer.
Mar 03, 2016 | Vulcan Kitchen Appliances - Others
Fryer turns on heats up and then will not keep temp.
You would be correct in your assessment to check the thermostat.
Jul 29, 2013 | American Range AF45LP Deep Fryer
It will not turn on
Hi Woodman22191,
I suggest that you do a couple of visual inspections first before doing anything drastic. Here's a list of things that you should check :
- Is the magnetic cord assembly properly attached to fryer socket ? - Is the electrical cord assembly plugged into electrical outlet? - Is the Power ON/OFF Switch is set to ON? - Is the Heating Element Assembly correctly assembled? Make sure Heating Element Assembly is properly installed on base. - Are you using too much or too little oil in the pot? Make sure that you use the recommended amount of oil in the oil pot.
If these things above does not fix the problem, you may need to Reset the Fryer. - Press Reset on Heating Element/Control Panel by inserting a paper clip or any small pointed object into the opening labeled RESET.
I hope this solves the problem. All the best to you. Good luck.
Dec 06, 2010 | Hamilton Beach 35030 Deep Fryer
I have a deep fryer. The heating element does not
Probably the heating element or the control has failed.
Feb 16, 2018 | Ultrex 607-922 Deep Flash - Double Filter...
Emerilware fryer wont power up FR7009001
You can go to T-Fal website they have replacement parts the new element is $101.99. i need a new element also but thinking of buying a whole new unit and keep old one for parts
Jun 11, 2009 | Emerilware FR7009001 Deep Fryer
Deep fryer won't turn on
I had the same thing on a Presto deep fryer. I removed that back cover and traced the wires from the AC inlet. One lead goes to a switch that activates when you slide the heater into the case so the heating element will not turn on if it is not in the case. I removed the switch, pushed it in and out a few times, verified that it works with a multimeter, reassembled everything, and "presto", it works. Maybe I was lucky, but it worked for me.
Aug 21, 2008 | Kitchen Appliances - Others
Bravetti Deep Fryer-Model EP65
I have Bravetti Platinum Pro Deep Fryer model EP65 but my heating element was damaged, I debating to sell parts or try to find a new heating element.
Apr 01, 2008 | Bravetti EP4305FS Deep Fryer
My GE 168997 is not heating up enough..
call and complain. possibly ask for a now one
Jan 07, 2008 | GE 168997 Deep Fryer
Wells F-49 21148 Deep Fryer Logo
323 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Raymond Koonce
Level 1 Expert
Dennis Boxerman
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
