I wish to take continuos exposures with olympus E510 ie every minute, as with my Olympus E10
Comments:
Sep 14, 2007
- Hi manual supplied with E-510 is not as detailed as the old E-10 will search for intervalometer in index, thanks blakey
Sep 14, 2007
- I need the function for wildlife photography, the the length of usb cable if available needs to be 5 or 10 metres second problem would be battery life of laptop or PDA, looks like my new E-510 is redundant already, good job I kept my E-10 will have to buy 300mm lens adaptor if I can find one, thanks blakey
You may need to have the camera plugged into the computer and operated by the software that came with it. It might have a feature there called intervalometer.
Comments:
Sep 14, 2007
- Like I say, check the camera software when the camera is plugged into the usb. If there is a cable release accessory available, sometimes these are electronic and have this feature built into them.
Was this helpful?
Yes
No
Popular Solutions for Olympus EVOLT E-510 Body Only
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use...
(More)
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use the external flash. Too bad Olympus didn't think of this earlier. Any other thoughts?
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some...
(More)
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some cases take out the battery to have it unlocked and to be able to take a few shots again
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn...
(More)
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn the mode wheel or just tape the wheel gently it switch off again. is there a solution?
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in...
(More)
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in P, S or A modes, although the camera functions as normal in Auto or the pre-configured scene modes. Any ideas?
