Question about Projection Televisions
Password default on mitsubishi TV
I Forgot password to open up Mitsubishi TV model VS-4503R projection TV. It's 4 numbers that are a password number to open up the TV. I was hoping to get like a default 4 number pass to open up and recieve input signals. Does anyone know ??
SOURCE: Mitsubishi 60 inch projection
They are not BULBS by any stretch of the imagination. They are CRTs (Cathode Ray Tubes, also known as "picture tubes," and each of them are small television screens, in essence), which are optically enlarged for projection onto the back of the front screen. Don't be tempted to think that you will merely be able to replace a "bulb" and have everything work!
Although you will be able to replace all of the components on the PC board if necessary (they all remain available), and may be able to fix the coolant leak that caused the failure, the CRT may have overheated. Considering the advanced age of the television, the tubes are likely already somewhat burned-in. Best to just dispose of the set.
Posted on Nov 20, 2007
  • 261 Answers
Sounds like a convergence issue or the CRT is going bad. If that is the case it wouldn't be cost effective to repair. Scrap it and get a HDTV.
Posted on Feb 09, 2008
  • 5138 Answers
SOURCE: just got a mitsubishi rear projection tv model
Replace Both of your STK392-570 they are big black ICs will have part number on them MATS Electronics 1-800-628-1118.
Posted on Aug 08, 2009
SD Tech
  • 14553 Answers
SOURCE: WS-55511 Mitsubishi projection TV is stuck on INPUT 4.
This model was first made in 2002 and is a V21 Mitsubishi chassis.
I presume the front input or device button does not do anything.
This (if it is a WS-55511) has an option code that can be accessed. It will reset everything back to the condition the set was in when it was new in the box; once executed you will have to put it in the cable band and autoprogram it----email me if you need instructions for this and I will give them to you.
If this was helpful I would appreciate a vote from you.
Posted on Aug 12, 2009
  • 1121 Answers
SOURCE: Blurry mitsubishi projection VS 5041
there a one or more defective tube needs to be replaced is typical efect when is tube end of life.
Posted on Jan 02, 2010
SOURCE: i have a mitsubishi vs 50707 projection tv, sound but no picture
Is the Lamp ok? Go to the rear of the set and turn on the set with your remote while looking at the vent slats. If you can see a bright light through the vent slats then your Lamp is working. If the lamp is on and you have sound and no pix, then the Digital bd is in what we call "Video Mute" and will have to be replaced. Also make sure that the Lamp Door is installed and the screws are tight
also check to ensure the following.....
1. re-seating the DVI cable on both sides
2. Check to be sure the lamp door sensor is closing (that is not your issue but i thought i would post the complete answer)
3. Check colorwheel is spinning up (should be a low hum, and not sound like a fan)
*** it is very possible it is a failed colorwheel, but the set should go into shutdown, so it is probably not the issue.
4. If the set has sound but no picture replace DMD board....
If the set is working and then just stops working best bet is the DMD ( i would not replace just the dmd it is cheaper in most cases and much easier to replace the lightengine) but if the set just is not working and just failed and is now always not working best bet is the digital board.
If you have an osciloscope you can measure the video signal from the Digital board and see if it is present with the no picture, if it is then it is a bad DMD but if the video signal disappears of then you have a failed Digital board. You can not us a computer USB scope, they can not read most of the data from the digital board since they use multiple scan rates and wont trigger on them for some reason, a old school scope works best i have found, or one of those new LCD scopes that have an auto trigger work well i have found that it is all i use anymore.
you can find a service manual with schematics at a very cheap price at ebay......
Posted on Aug 30, 2010
0 characters
1 Points
Forgot password to unlock vchip
Use a keyboard though usb port or take to cable provider.
Jan 20, 2014 | Mitsubishi VS-6055 60" Rear Projection...
Cannot get my compoent cables to show on the tv mitsubishi hd 1080 series model vs-A50
Assuming the cables are good etc. this set has 3 hidden menus, one is the OPTION menu which will reset almost all settings back to default.
I have seen it cure no sound, no video, all sorts of odd things--it will not affect convergence which is stored in another area but a missing or non working input it may cure.
I have the 4 number code for doing this but you have to have a working original Mitsubishi remote--universal will not work.
Let me know if you want to try it and I will provide the code and general instructions for doing it.
Dec 21, 2012 | Mitsubishi VS-50607 50" Rear Projection...
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Forgot password for parent control
If you have the original mitsubishi remote and confirm actual model number I can tell you how to do a hard reset of the Tv which is done with the remote.
This will clear and restore all settings in the set to factory default.
Oct 16, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv wont turn on its a mitsubishi wide screen model number WS-65809. also forgot password for parental locks so when it is on cant watch anything but Disney, and Nickalodian!!!
I can help you unlock your Mitsubishi HDTV V-Chip at least, for when you get it back on.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Mar 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-5046
i have a 50in mitsubishi tv model vs5046 the screen protector is crack the tv works fine but need to know where can i purchase a protector or its there a number. also how much will this cost.
Oct 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
I hope that helps.
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
TV Repair
Feb 09, 2008 | Projection Televisions
Projection Televisions Logo
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
