Question about Kenmore Dryers
I have a Kenmore Series 90 gas dryer. Works fine.
I have a Kenmore Series 90 gas dryer. Works fine. When the dryer is not in use, sometimes smell a faint gas smell in the area around the dryer. The gas supply line is ok. Any solutions?
bpell
  • wpelletier Apr 14, 2009
    I had the supply line checked by a plumber and there were no leaks.
  • May 11, 2010
    Have you tried using a leak test solution (you can either buy a commercial product or just put dish detergent in a little water) to make sure there are no leaks at the supply connection? It's not always possible to tell by eye (or nose).
    President:
  • 2,992 Answers
The only source of a gas leak from inside the dryer itself is the gas valve. They can sometimes leak a little gas when you first turn the gas on after hooking it up. If your gas pressure is normal (and I'm guessing the plumber checked it) and your other gas appliances are working properly, the dryer gas valve is faulty and should be checked by a qualified appliance servicer.
Posted on Apr 15, 2009
Kenmore 90 series gas dryer no heat
The gas ignitor most likley is not functioning. They do not have a pilot light like appliances in the oold days. They must ignite a new flame each use. if you don't smell gas when you try and use, then it is the ignitor and the computerized sensor tells the gas not to turn on because the initial flame has not been created.
Oct 08, 2012 | Kenmore 63942 Dryer
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
424 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
