Question about Polaroid Televison & Video
My polaroid 32"LCD TV has no picture
I bought this in Mexico Sam's Club, have it hooked up to a voltage regulator, and after a brief brown out, my screen no longer displays. The TV can be turned on and off, but nothing but a black screen. I suspect the florescent lamp is blown and I would like to try to procure the part myself to repair.
  • Scott Ferris
    Scott Ferris Apr 22, 2009
    Hi-
    Thanks for your reply. As I mentioned above, this LCD is in Mexico - and, I'm in Seattle! The warranty has expired. Therefore, I am keen to troubleshoot myself, and procure the likely part and fix myself. I realize that this voids any warranty, but if I have to invest several hundred dollars to repair in the out skirts of the Riviera Maya, then I might as well just get a new set.
    So...how can you help me figure out what is likely the problem, then source (myself) any requisite replacement parts?
    S-
    Sergeant:
    Champion:
  • 219 Answers
Hi, as u told that the TV can be turned on/off but only black screen appears.Then there might be problem with the Florrescent Lamp or IC. I have the same problem with my TV.I called the Mechanic for repairing it as it is not safe enough to repair it myself. So my advice would be to call the mechanic.Rest is upto u whether u want to take the risk. Thanks! Sandy
Posted on Apr 23, 2009
  • 315 Answers
This actually seems to be a fairly common problem with these and other brands of LCD's. The first thing you should try is a hard reset. Unplug the tv before going to bed then plug it back in tomorrow the morning (Or about 6 hours). If this doesn't work you have an essential failure which will need repair. The two main causes of the type of problem you are having is either a poor solder connection right on the board where the screens connects to the TV, or the second ,a faulty LCD Panel. By the description you have given me it is just a poor solder connection. Of course there is no way to guarantee it's not the LCD Panel itself without looking at it for you.
Either way it will need to be attended to by a technician if the reset fails. I recommend checking the warranty information that came with the unit to see if there is any way you can recoup some or all of the cost of a repair which will be needed.
Here is a link to the Polaroid warranty service site if you need it: POLAROID SERVICE
Posted on Apr 22, 2009
Seized up with smoke coming from the back of the TV
Check and replace the main power regulator board. Components on it have been burned due to voltage fluctuation. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 03, 2014 | Polaroid TDA-03211C 32 in. LCD HDTV
32' polaroid lcd tv. no picture when you turn the set on the light turns green but i get no picture.
Possible that the voltage is not supplied to the drive board, Check the line of the +B to the main board as the controller is working as well as the power supply.
It is possible that a fusible resistor has opened out in advance but if you can trace this on.
However if you get voltage on the convergence Ic's then it might be defective in not supply the drive.
Aug 26, 2010 | Polaroid Televison & Video
No picture have sound stopped while watching
Ur tv the LCD inverter board is dead.Replaced the LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy an refurbish LCD inverter board for the replacement.It a long board in shape.
May 31, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
No picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Nov 08, 2009 | Polaroid TDX-03211C LCD TV
Vidio blacks out quickly after turn on TDA 03211c.
10V 450uf cap in high Voltage section... replace both not just the one. Caps tend to dry out and cause short on nearby regulator if left go too long. Do not continue to run the TV without replacing the caps first that are leaky. They are the Larger of all Electrolytics on high voltage board and manuf is Sanyo Brown with silver stripe. Typically the bottom of the two caps goes first.
Oct 18, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv turned on then lose picture,but keeps sound.
could be one of two problems, either the lcd back light, which a new screen is needed, or the control box, both run about 200 dollars from polaroid, I have a 32 inch screen, I bought it cause polaroid said that was my problem only to find out that it was the control box.
Apr 06, 2009 | Polaroid Televison & Video
Setting Polaroid 32" HDTV for 1080i
You must hook up into the hdmi in on tv or use the red blue green video hook ups and it will work switch itself dont forget the red blue audio cables!
Dec 11, 2008 | Polaroid FLM-3225 32 in. LCD Television
Insignia NS-LCD32 TV
The tuner section, and or the voltage regulator circuit that supplies it is probably failing. The service rep for your set may be able to order a new tuner module and install it. This is not a type of repair you can do yourself.
Jerry G.
Jun 18, 2008 | Insignia IS-LCDTV32 32 in. Television
Akai LCT3201AD 32 in. LCD picture stretched around the corners
This set has several differant aspect ratios, could you have unwittingly change it to a zoom or expand by mistake?
Feb 07, 2008 | Akai LCT3201TD 32 in. LCD Television
Televison & Video Logo
57 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
