Question about Samsung DVD-VR357
NO POWER MY SAMSUNG DVD-VR357 UNIT DOES NOT POWER UP. I CHECKED THE FUSE WITH A CONTINUITY TESTER BY KEEPING THE LEADS ON AND SHAKING IT TO ENSURE THAT THERE WAS NOT A LOOSE FILAMENT CAUSING THE PROBLEM. IT TESTED FINE. I ALSO CHECKED THE LINE CORD FOR POWER TO THE UNIT, AND THAT ALSO CHECKED OUT FINE FOR POWER AT 120 VOLTS. IS THERE ANOTHER FUSE OR RESET BUTTON THAT NEEDS ATTENTION. IF NOT WHAT ELSE SHOULD I TRY BEFORE IT GOES IN THE TRASH
  • 25 Answers
Check power transformer inside.
Posted on Apr 16, 2009
I purchased new batteries for my IDEAL Ideal 61-065 Voltage Tester, but I still can't get the unit to perform contiunity checks. The light on the left will not come on. I want to ensure I have the...
IDEAL 61-065 does not have continuity function and therefore does not need batteries. If you have different model (like 61-076) then check if leads are good first.
Sep 16, 2011 | IDEAL 61-065 Voltage Tester
How do I check if a fuse has been burned and how do I obtain a replacement fuse?
Good question-- let me ask a couple, and see if this helps us both:
1.) Is it a glass cartridge type fuse (Small-- about an inch long, and 1/4" in dia?
Often you can see inside of these, and tell, that the tiny "filament-like wire' has blown-- Usually there is some balckened residue inside the glass.
2.) Other fuses are best removed from their holders, and checked with a continuity tester. (Be sure to remove the power cord from the wall before touching the fuse.)
3.) If you can get an Ohmmeter-- or a continuity tester (some call them multi-testers)
You take the fuse out, put it on the bench, take the 2 leads from your tester-- touch the tips together, and you will get an indication of what is a CONTINUOUS circuit..
This is the same indication you will see for a GOOD fuse..
If a fuse is blown-- it will be the same as when you hold the 2 leads apart-- Infinite ohms or OPEN.
Does that make sense?
Mack B
Dec 28, 2010 | Fujitsu 18C1 Air Conditioner
Lost my manual and need to know how to test a car fuse
With a car fuse, you are only looking for continuity.
Remove the fuse from the car.
Set the tester to "continuity", if you have it.
Touch the leads to the ends of the fuse, if it buzzes, the fuse is good.
If you don't have "continuity", set the tester to ohms, the lowest setting, possibly 200.
Touch the leads to each end of the fuse and you should get close to zero, probably 0.1 to 0.5 ohms.
Gary
Dec 15, 2010 | Actron CP7672 Digital Multitester
My samsung vr357 will not load a disc
The laser lens needs cleaning . You can try a DVD cleaning disk from Target or Walmart . If that doesnt work , the player will need to be opened and manually cleaned
Apr 20, 2010 | Samsung DVD-VR357
Vr357 no power
If you take the top off of the unit there should be a glass fuse right behind the power chord. If you have a multimeter you can check and see if the fuse is ok by setting the meter on 120 ground the black wire to the chassis and put the red probe on the fuse out side to check for power. If the fuse is bad you can replace it, but you may have to unsolder it.
Jan 21, 2010 | Samsung DVD-VR357
Need to reset samsung dvd vr357
With the unit on, hold down the FFW and RW buttons TOGETHER. Do this in front of the unit, NOT ON THE REMOTE CONTROL.
The unit should either open the tray or say REST OK on the front panel.
Hope this helps!!
Jun 25, 2009 | Samsung DVD-VR357
DVD-VR357 plays audio CD's and VHS but won't play DVD's
the best solution for ur problem is change the lens(optical pick up head)
Oct 29, 2008 | Samsung DVD-VR357
Menu will not show up on tv
Try changing channel on tv set, it may have changed on accident.
Aug 01, 2008 | Samsung DVD-VR357
Samsung DVD-VR357 Won't play ANY DVD's
I have the same problem. How do you reset the unit?
Jan 09, 2008 | Samsung DVD-VR357
Samsung DVD-VR357 Logo
194 people viewed this question
Henry  Thomas
Henry Thomas
