Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
Hii this ajit plz help me out in small probs dat i have resetted the DIR 300 but the default password n username was admin and admin after resetting it is not accepting the same thing plz help me tell me solution for this wat do for this ajitpwr@gmail.com plz do reply me
Sorry i have this problem by myself n i wy should i tell u people
Posted on Apr 15, 2009
I have a d-link dir-615 password won't work need to reset it.
put the special reset button at the back for a few second with a pin.
When reboot ready,
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In
Then change settings and passwords.
Jan 01, 2014 | D-Link DP 300 (DP-300) Print Server
I am trying to login as admin, to be able to change the default password and secure the signal, but the default username does not let me log in. I'm using 192.168.0.1, login-admin, password-(blank). H
Looks like you wil have to do a facotry reset. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Dec 14, 2011 | D-Link DIR-615 Wireless Router
All D-Link Dir configuration done but I can't access internet,why is that?
Reset your router back to it's factory settings by holding the reset button for about 5 seconds.
I have provided a list of the most popular router brands. If it does not work you may need to
google what your specific model's default IP address/default username/default passwords are, for
example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it
can depend on where you obtained your router. If you purchased it yourself from a store then the
standard defaults should work. If you obtained your router from your Internet Provider you may
need to contact your service provider. It also may depend whether it's an old or new model router
as well. And you may need to press and hold the reset button on your router several times before
it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is:
192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or
192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 06, 2011 | D-Link DIR-600 Router
I want to configure my router through web,but i ca not connect at 192.168.0.1 web address..
The default IP for the DIR-300 is 192.168.0.1. First, make sure you're entering "http://192.168.0.1" in your browser's address bar. In some browsers, if you try entering just the numbers, it won't work.
If you can't access the setup page at all, that address may have been changed. If this is the case, or you can't log in because you don't remember the username and password, you should reset the router which will restore the factory defaults.Press the recessed rear-panel reset button and hold it in for 10 seconds. Release it and the router will restart. The defualt IP (192.168.0.1) and username and password (both admin) will be restored.
Aug 16, 2011 | D-Link DIR-300 Wireless Router
I lost the password of my D-Link DIR-300 Wireless Router
Press and hold the reset button on the rear portion of the router. This will reset the old password. Make suer to log back on to your router using the username administrator and password admin
Jan 24, 2011 | D-Link DIR-300 Wireless Router
How do I reset my D.Link DIR-625 router if I forgot the password?
Thank you for posting on fixya. Am pleased to help you.
I understood your issue and I would request you to follow the below steps. Note: Once reset is done, DIR-625 will have the default settings.
Look on the rear side of DIR-625. There should be a small hole, usually just to the
left of the power jack on DLinks. Inside that hole is a small button. Find
something small enough to press and hold it while the DIR-625 is powered up.
While pressing and holding, watch the lights on the front. With DLinks, its
usually the M1 and M2 lights that will go solid while holding the reset
button. Keep holding the reset until they start blinking. Its now reset.
To reconfigure:
1. Type in 192.168.2.1 on your web browser. 2. At Router's login page, type your username and password(Default Username: admin Password: (blank) ). 3.Once you are in, browse the different tabs for various settings. [ Contact DLINK customer support for details. Toll free number on products box] .
Thank you an have a great day. Feedbacks are appreciated.
Nov 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
Lost my password for d-link
You can reset the D-Link back to the default settings by power up the D-Link and press and hold the RESET button at the back of the router until all the LEDs flash.
Open a browser and enter the configuration URL
http://192.168.0.1
The default login = admin
The default password = blank (just press enter)
Sep 18, 2010 | D-Link DIR-300 Wireless Router
Ip address of d-link DIR-300
192.168.0.1
default login is
username admin
password leave blank
Aug 21, 2010 | D-Link DIR-300 Wireless Router
How do I put a password on my d-link 300 Dir Router
You need to access your router's web configuration interface. To do this, you need to connect a computer directly to your router and visit http://192.168.0.1 using any web browser.
When prompted for a credentials:
user name = admin
password = <blank> leave blank
When you successfully access the interface, you can set an admin password so that not everyone can access the administration page.
Feb 12, 2010 | Office Equipment & Supplies
I can not install DLINK Wireless G Router, have reset it a number of times, I can access log on at http://192.168.0.1/ but it will not accept admin as user name and password. Using CD it fails at step 3...
Maybe you did a soft reset, try a hard reset by holding down the reset button for 60 seconds, unplug it for 10 seconds, then plug it back in. See if that helps. IF you cannot log on, try putting password as admin leave username blank.
Nov 09, 2009 | D-Link DIR-300 Wireless Router
Computers & Internet Logo
46 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
