Question about Mtd 22" Yard Machine Push Mower
I have an mtd yard man mower that wont stay running, Any suggestions why?
    Problem Solver:
  • 6 Answers
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Posted on Apr 14, 2009
Manual for Yard man MTD model 379C manual
You might try Amazon.com
enter your model number and manuals
Nov 20, 2015 | Mtd Garden
What is the sprkplug gap for a 6.5 briggs &statton
Contact MTD if your manual doesn't cover this, or buy a shop manual. Or go to the Briggs & Stratton website.
May 20, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a zero turn Yard Man 42 inch mower, it stops running when I am mowing ,it acts like a safty switch, when it stops the mower starts up again.
It could be a problem in your seat safety switch. You can enter your model number here: www.mtdparts.com and see a schematic.
Oct 11, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Lawn mower wont stay running only five mintues at a time it like it gets hot fast and then turns off
Check the Float bowl assembly.
Below the carburetor, there is a rounded metal object about 3 inches in diameter. Find the hex nut at the center-bottom of the bowl and unscrew it.
Pull the bowl off, being careful not to twist the float which hangs from the carb. Clean it out well, check the gasket for good seal and replace.
Then check the priming bulb, that round flexible thing you press on to prime, and make sure it is not torn.
Lastly, Try running the mower without the air cleaner for awhile. If it runs good that way, you need a new air cleaner element.
Jul 30, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd rider trans belt will not stay on
it sounds like the spring got stretched or came loose. or wrong belt or the dowl pins around the pully came off?
May 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd 22" Yard Machine Push Mower Logo
651 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
