Question about Refrigerators
Need help in finding weight for above fridge
Help!!!! My boss has asked me to find out the following: "get the exact weight of this older refrigerator. I am only interested in weight." Fridge is a Whirlpool model#ET21DK and ET21DM??? - that's what it says on the door. 20.8 total cubic feet of fridge & freezer. Thanks, Kim
  • 297 Answers
Go mingle here some knowledgable gents here
http://www.applianceblog.com/mainforums/showthread.php?t=1181
Posted on Apr 14, 2009
Honestly, I need to know the approximate weight of a 1990 Ford Mallard Motorhome and cannot find that information anywhere online.
Hi Jenn:
You could get the exact weight without too much trouble.
If there is a gravel pit nearby (or a highways weigh scale) all you need to do is ask and they will let you drive over their scales.
Ta Da!!!! The exact weight.
If you look at your registration there should be a place where the GVW is recorded.
Aug 29, 2015 | Cars & Trucks
I have a supreme weigh sw02 digital pocket scale i need to calibrate and need help
500ml 0f water is exactly 500g, measure that volume and put it in freezer bag and use as calibration weight, or if you have friend with scales - borrow from him scale weights.
if you use water - accuracy of the scale will not be absolute, it may vary few g either way.
another way - go to shop and buy 500g block of butter - put it on the scale in the shop - remove or add as you need till you have exact 500g, shop scales are accurate on that weight within 2g
do not forget to vote if you find this answer useful...
Jan 02, 2015 | Health & Beauty
Screen will not turn on it came on then it stop
Try resetting the system. Follow these instructions:
  • Push the RES or RESET button with a pen or similar object.
  • The button location depends on your Boss model.
  • Turn the power on.
Download the correct manual for your model in order to locate the RESET button:
Boss Car Audio Manuals
Find your Boss manuals using the link above.
Sep 04, 2014 | BOSS AUDIO SYSTEMS Car Audio & Video
I need help finding latest traffic fines for my boss but i have no idea where exactly to look please help!!!!!!!!!!!!!!!!!!!!!!!!!!
Go back to where you paid the fine, tell them your plight. They keep copies of everything...forever. lol.
Sep 11, 2013 | Cars & Trucks
The fridge door will not stay closed. I changed the gasket, tightened the door screws, cleaned the contact area and it still pops open.
After all the good ideas you've already tried, the next things on your list could be:
(a) level the floor under the fridge - they often sag under the heavy weight of a loaded fridge due to moisture/rot.
(b) level the fridge itself - using the leveling legs. If the fridge continues to have a problem with
the door poping open, try raising up the front of the fridge above level.
(c) unload the door pockets - making the doors lighter may help solve the problem.
Aug 17, 2011 | Refrigerators
I WOULD LIKE TO FIND AN ELECTRICAL AND A MECHANICAL DIAGRAM OF G.E. MODEL# GTS181BMRWW SERIAL#SA510124
I found info for this fridge as model GTS18IBRWW. I couldn't find electrical diagrams, but found part and other info for it here.
You may have better luck searching with the part number I supplied above. Service manuals are harder to find, as many times they're made available only to factory trained service personnel - but you may find training documents here and there for similar models - rather than your exact model.
Lastly, you may have the best luck simply asking about the specific problem you're having with your fridge. Others may have solved the same issue in the past - but don't have the electrical & mechanical documentation that you're asking about.
I hope this helps & good luck!
Oct 21, 2010 | Refrigerators
Boss c705 chaos "manual" try-en to find
What info do you need? All amps are exactly the same and the manual only differs for specific specs and db ratings!!
Nov 03, 2009 | Boss C700 Car Audio Amplifier
Boss RE1000 User Manual
It's not even available at the 'Boss' site.
The following link (and the only one I've found) will bring you to a site with the RE1000 manual in PDF format.
User Manuals
Unfortunately, they charge $9.99 for a copy.
Hope this helps.
Mike
Jul 24, 2008 | Audio Players & Recorders
Fisher turntable M-720 need to set weight and return levels
Hi mariahom
Setting the tracking force is an easy task. Try this method.
  1. first thing to do with the tone arm sitting above its rest, rotate the weight on the end of the tone arm until the tone arm is balanced in the middle. neither up nor down, just right in the middle.
  2. calibrate the numbered rotating collar on the weight so that 0 is exactly on the reference line on the tone arm.
  3. then turn the weight and numbered collar together to the tracking force that you are seeking. Most moving magnet cartridges need at least 1.5grams of weight. Set it for 2 grams if you are unsure of what your is or needs.
  4. adjust the anti skate dial(if you have one) to the same number as the tracking force you are using.
At this point you should be able to gently bounce the tone arm on your index finger(not above the record of course). This is about all there is to it.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jul 13, 2008 | Fisher Audio Players & Recorders
Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Jun 13, 2008 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
