Question about Magic Chef Refrigerators
Water runs under the vegetable bins
I'm assuming when the freezer is defrosting the water is draining somewhere and collects under the vegetable bins rather than the pan underneath. it has sealed coils
  • 297 Answers
There should be a collecting channel with a hole and a tube reaching down to somewhere above the cooling compressor (Back of unit) where it should evaporate with the heat.
Most people never clean that hole and tube simply because they do not know what is for or the manual is silent. Sometime can be jammed with little icecube. I us thick plastic line from toy to clean, electrical wire with copper core not naked is also oke. Do not put wild force. This is the cooler part. The deep freezer part needs defrosting on temporarily basis and for that you need some small low bin to start collecting or keep on mobbing the floor.
Posted on Apr 14, 2009
Water collects in the fresh meat compartment (in refrigerator section). Ice forms on the bottom (under the fresh vegetable bins) of the refrigerator.
Your drain is likely plugged and not allowing the defrost water to drain out. You will need to remove the rear freezer panel and thaw the drain. I would recommend installing a drain heater while you have it apart. They are inexpensive and easy to install. They come with installation instructions.
Kelly
Mar 23, 2011 | Refrigerators
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze....
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
My Roper refrigerator collects water in both vegetable bins. Help!
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jan 21, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a GE Profile TBX19PAYBRWW, there is water dripping on the inside of the refrigerator and collecting under the vegetable bins and then eventually runs out the front of the door. What can I do to fix...
OK, there is a dranage tube located somewhere at the back or so, and it is probably cloged or piched. Remove your contents of the fridge as necessary, located the tube, check it out, and clean/unpinch as required. That should get things flowing again.
Oct 05, 2009 | GE Profile 19.0 cu. ft. Top Freezer...
Water collects under the vegetable bins but there is no sign of water anywhere else.
The defrost drain inside the freezer , behind the back wall , is frozen . Remove the food , then remove the rear freezer panel , If you have an icemaker , it too , will have to be removed . Use a hair dryer to melt the ice layer below the coils . Once you see the drain hole , defrost the hole , hot water helps sometimes . Once the hole is defrosted , use a small tube inserted into the hole and blow thru it to clear any debris inside . Reinstall removed parts and problem solved . Easy repair .
Aug 18, 2009 | GE GTS22KBP Top Freezer Refrigerator
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Water in bottom of "fridge" and in vegetable bins
Hi: I'll assume this is should be a frost free freezer. If so the defrost drain is clogged and the water isn't getting to the evaporator pan. Without knowing the specifics although it sounds like a top freezer. Look for a drain below the evaporator coils. The will be in the back of the freezer behind a panel. Some models have a drain hose behind the ref. Use a strong solution of clorox and water to clean it out. The parts list or diagram of the fridge will help you find the drain. If you don't have it enter your model no. at sears.com parts direct. I hope this helps, Jeff
Jun 02, 2009 | Refrigerators
Water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
Jan 27, 2009 | Kenmore Refrigerators
Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Mar 21, 2008 | Refrigerators
Refrigerators Logo
311 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
