Question about HP Photosmart 2610 All-In-One InkJet Printer
Header my fax stuffed up on me the other day and now , my header on my fax is saying my name when i need it to say my business so can any one help me in this problem
    President:
  • HP Master
  • 2,022 Answers
Change the prefrence setting
Posted on Sep 24, 2007
How can i change the header as the company name as changed in Canon Fax L140
scan on to pc, edit in microsoft word or offic, rewrite desired letter head
Feb 12, 2013 | Canon i-sensys fax-l140 laser fax...
We have a FAX-2820. this is a dumb question, but does the fax header line come from the sender when we are receiving the fax? Does a header go out on any fax we would send out?
Yes, The fax header should show you who sent the fax to you. Every fax is supposed to have a terminal ID (senders fax number and Name)
Andrew
Sep 22, 2011 | Brother IntelliFax-2820 Laser Fax
We have taken delivery of a fax from within our business but need to change the header/business name that recipients see when receiving faxes from us
Press the Menu/set key, then down arrow untill initial setup, then press, menu/set, then down arrow to station ID, then menu/set. From here you can change the info you need to change.
May 08, 2010 | Brother IntelliFax-2820 Laser Fax
Change fax number
1 Press Setup. 2 Press 3, then press 2. This selects Basic Fax Setup, then selects Fax Header. 3 After Your Name appears, enter your name using the numeric keypad, as described in the next section, enter text, then press Enter. 4 Using the keypad, enter your fax number. 5 After you finish entering your fax number, press Enter.
Apr 04, 2010 | HP PSC 2210 All-In-One InkJet Printer
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Sep 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
How do i change my fax number
Changing the Fax Configuration
1 Click Start/Programs or All Programs/Accessories/ Communications/ Fax, and then click Fax Console.
2 In Fax Console, click Configure Fax on the Tools menu to start the Fax Configuration
Wizard.
3. On the Transmitting Subscriber Identification (TSID) screen, type the identification information (usually your fax number and your name or business name) in the TSID box. This information will appear in the header area of the faxes you send and identifies your
fax machine to the person who receives your faxes.
Aug 16, 2009 | Dell 942 All-In-One InkJet Printer
Fax header Ricoh 1013F
GEEZ, the 1013f, I beleive you have to access the user tools buttom, it is on the left side of the control panel. From there slect fax features, then select general/settins adjust, then program fax information, then slect fax header, from there you will use th alpha keys on the left side that double as the one touch keys. When you are done select ok!
http://copierquestions.websitetoolbox.com/
Aug 13, 2009 | Ricoh Aficio 1013F Copier
How 2 configure fax on HP laserjet 3050
If this doesn't answer your question, then let me know more specifically what you need.
Setting the time and date
To set the time and date
To set or change the time and date, use the following steps. If you need help entering any
information, see Enter text from the control panel.
1. On the control panel, press Menu.
2. Use the < or the > button to select System setup, and then press .
3. Press Menu to select Time/Date.
4. Use the < or the > button to specify either the 12-hour or the 24-hour clock, and then press .
5. Use the alphanumeric buttons to enter the current time.
6. If you specified the 12-hour clock, use the < or the > button to move the cursor past the fourth
character. Select 1 for A.M. or 2 for P.M., and then press .
-or-
If you specified the 24-hour clock, press .
7.
NOTE Make sure that you use two digits to specify the month and day, in that order (for
example, use “05” for May and “01” for the first day of the month of May).
8. Press Menu.
Setting the fax header
To set the fax header
To set or change the fax header information, complete the following steps. If you need help entering
any information, see Enter text from the control panel.
2. Use the < or the > button to select Fax setup, and then press .
3. Use the < or the > button to select Fax Header, and then press .
4. Use the alphanumeric buttons to enter your fax number, and then press .
5. Use the alphanumeric buttons to enter your company name, and then press .
NOTE The maximum number of characters allowed in the fax number is 20. The maximum
number of characters allowed in the company name is 40.
Apr 07, 2009 | HP LaserJet 3050 All-In-One Printer
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
