Question about Brother Office Equipment & Supplies
I have a Brother HL2070N printer. I have 2 computers and want to share the printer. I connected the printer via the USB port to Computer 1 and it prints fine. I set the printer to SHARED. Computer 1 has a direct connection to the internet via a wireless router. Computer 2 shares the internet connection via a wireless card. I cannot print from Computer 2. When I try to Add Printer on Computer 2 it does not see the shared printer.
    Brigadier General:
  • 3,614 Answers
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Posted on Apr 14, 2009
Can I connect 2 computers sharing a KVM Switch to 1 USB printer?
You need a USB printer share device such as this one http://www.amazon.com/IOGEAR-2-Port-Printer-Sharing-GUB211/dp/B001SEB45M/ref=sr_1_1?ie=UTF8&qid=1328912939&sr=8-1
Feb 10, 2012 | Brother Office Equipment & Supplies
Trying to connect 4 MACs to all in one Kodak 5250 printer and will not connect via wireless. I had to set up so that the other pc's have to print from one location via hardwire. I tried installing...
If you have one PC connected to the printer via USB you can share the printer to your Mac computers easily:
If the printer is connected to a Macintosh computer via USB:
1) Open System Preferences
2) Click on Print and Fax
3) Highlight the Printer and Check the box Marked "Share This Printer On The Network"
If the printer is connected to a windows computer via USB:
1) Download "Bonjour Print Services for Windows" from Apple's website
http://support.apple.com/kb/dl999
2) Install it on the PC connected to the Printer.
3) After Installing the Above, Run the Bonjour Printer Configuration Utility and select the Printer you want to share and it will share it over the network to all your apple devices.
Mar 02, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Want to use printer to scan document to my computer, printer says to check connection when scan button is pressed. printer is directly connected to computer via USB. what do I do now
USB/PARALLEL CONNECTION USERS:
The Check Cable message generally indicates that there is a communication or connection loss between the computer and the Brother Machine. To resolve this issue perform the following steps:
PART 1: VERIFY THE CABLE CONNECTION
1. Verify that you are using the proper interface cable with your Brother machine. Brother recommends you use an interface cable that is 6 feet (2 meters) or less, directly connected from the Brother machine to an available port on your computer.
a) For USB cable users, a type A/B 1.1 or 2.0 USB cable is recommended.
b) For parallel cable users a Shielded IEEE 1284 compliant cable is recommended.
c) Other cable configurations may work, however connection loss is common. For troubleshooting purposes, do not connect your interface cable through any hubs, splitters, docking stations, or other pass-through devices.
2. Check the cable connection to the brother machine. Remove the cablefrom both the computer and the Brother machine. Leave them unplugged for a few seconds, and then reseat the cable on both ends to ensure a secure connection. For USB users, ensure the USB cable is plugged into the Brother machine's USB Port, not the LAN port if applicable.
3. Restart the Brother machine. Cycle the power off for 15 seconds, and then back on.
PART 2: VERIFY THE DRIVERS ARE INSTALLED
1. Open the Scanners and Cameras Control Panel: Click START -> (SETTINGS) -> CONTROL PANEL -> SCANNERS AND CAMERAS (Note: You may first have to click on PRINTERS AND OTHER HARDWARE or HARDWARE AND SOUND)
2. Verify that the Brother scanner is listed. If the Brother scanner is listed, continue to PART 3. If the Brother scanner is not listed, continue to PART 6 to install the driver.
PART 3: RESTART THE WINDOWS IMAGE ACQUISITION (WIA) SERVICE (WINDOWS XP/VISTA USERS ONLY)
1. On the computer, Click on START -> RUN or in the START SEARCH line.
2. Type: SERVICES.MSC and press ENTER.
3. Locate WINDOWS IMAGE ACQUISITION (WIA) Service, and double click on it.
3a. If you are not able to locate the service, this indicates and operating system issue. This service exists on all Windows XP/Vista computers. Contact your computer OEM for further support.
4. Check the STARTUP TYPE, and make sure it is set to AUTOMATIC. If itis set to anything else change it to AUTOMATIC.
5. Verify the Service Status.
a) If the Service is STARTED, press STOP, and then press START to restart the service.
b) If the Service is STOPPED press START to restart the service.
*Note: If you receive any error message while restarting the service, orare not able to start the service this indicates an operating system issue. This service controls all scanning operations. If the WIA Service is not started, you will not be able to scan from any scanner, and refer to the Computer OEM for further support.
6. Close WINDOWS IMAGE ACQUISITION (WIA) Service, and close the Services window.
7. Attempt another test scan using the SCAN button on the Brother machine. If the scan is unsuccessful, continue to PART 5.
PART 5 - APPLY THE SCANNER PATCH BrWIARegRepair.exe (WINDOWS XP/VISTA USERS ONLY)
1. While connected to the Internet, on your computer, Click on START -> RUN
2. Erase anything in the open box and type: http://209.215.81.199/download/mfc/BrWIARegRepair.exe
3. Click OK
4. Click SAVE. For the Save-In location choose DESKTOP and click SAVE again. This will save the file to the Desktop.
*NOTE: If DOWNLOAD COMPLETE appears, click CLOSE
5. Go to the Desktop and locate the zip file BrWIARegRepair
6. Click UNZIP. You will receive a message stating: 1 file unzipped successfully. Click OK and close the WinZip Self Extractor window. Thefile will automatically be extracted to a Brother folder on the desktop.
7. Go to the Desktop and locate a Brother folder. Double click the Brother folder and then double click the BrWIARegRepair.exe file in the folder.
8. When you see the following message: SETUP COMPLETED PLEASE CLICK OKAND THEN RESTART WINDOWS FOR THESE SETTINGS TO TAKE EFFECT. Code X. (NOTE: X will be 1, 2, or 3). Make a note of the code and restart your computer.
9. Once the computer restarts attempt another test scan using the SCAN button on the Brother machine. If the scan is unsuccessful, continue toPART 6.
PART 6: UNINSTALL AND REINSTALL THE BROTHER DRIVERS
Before you perform the uninstall, ensure that you have the software CD or access to the Internet to download the software needed to reinstall.
1. On the computer click on START -> (ALL) PROGRAMS -> BROTHER -> MFL-PRO SUITE -> UNINSTALL. If the software is not present continue to step 4.
2. When asked to confirm that you want to completely remove the software, click OK.
3. When the uninstall is complete, you will be prompted to restart the computer. Click YES.
4. Once the computer restarts, reinstall the software. For instructions, refer to the solution: How do I setup/install my Brother machine with a local (USB/Parallel) connection? #OR- How do I download and install my Brother machine using a local (USB/Parallel) connection?
5. Once the software has been reinstalled, attempt another test scan using the SCAN button on the Brother machine. All drivers have been reinstalled, and the issue should be resolved.
Oct 31, 2010 | Brother MFC-685cw InkJet Printer
Can the HP PSC 2410 printer be shared between 2 computers?
generally the printers with single USB port are dedicated for use with one computer.
However, depending on the way you connect the computers you can share the printer with more than one computer.
1. SET THE SECOND COMPUTER UP AS A NETWORK PRINTER
This is one of the most common ways to connect two home computers to the same printer. The advantage of this technique is that it doesn't cost you anything extra. You do require some computer literacy in networking though.
Firstly you physically connect the first computer to the printer via the provided cables. The second computer now needs to be set up as a network printer to have printing capabilities. The computer not physically hooked up sends a message via the network to the computer which is physically connected to print.
To set up the network connection in Windows follow these steps:
-Open the control panel
-Select the network or network and sharing icon
-You should see an icon named file and print sharing or simply print sharing. Turn on printer sharing if it is off.
(This requires your two computers to already share a network connection; otherwise you will have to set this up).
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/print_sharingw.mspx?mfr=true
2. PURCHASE A PRINTER SWITCH
A simple old fashioned way to connect two computers to one printer is by hooking them up to one switchbox in the middle. This switch is what is connected to the printer. This is a similar method to using a router to distribute the Internet to more then one computer.
This method is good for people who aren't very computer literate when it comes to networking. All you have to do is plug the cables in and off you go. However, it has one large disadvantage which is that the computers and printer all have to be in close proximity for the cables to reach.
The printer server should support the printer so that you can get maximum functionality from the printer device (including the multifunction feature).
http://cgi.ebay.com.au/Gray-Steel-Two-Ports-Printer-Sharing-USB-Switch-Box-/180502082365?cmd=ViewItem&pt=AU_Computers_Printer_Accessories&hash=item2a06c3333d
3. You can buy a printer server but for that you need to make sure the device fully supports the printer you have got including the multifunction features. Both computers will need to have network connection.
Something like http://www.netgear.com.au/au/Product/Print-Servers/Wired-Print-Servers/PS121
or
http://www.belkin.com/IWCatProductPage.process?Product_Id=354892
May 07, 2010 | HP PSC 2410 All-In-One InkJet Printer
I had computer problems today and had to swop my hard disk into another computer box. After doing that my Brother MFC8460N faxed and copied but does not want to print from my computer at all. I uninstalled...
Trying connecting the USB printer to some other computer,
to see if the other computer recognizes the printer.
Try a different USB port on your computer.
Try a different USB-device (memory-stick? camera?) into your USB port, to confirm that the USB-port is working.
Jul 16, 2009 | Brother MFC-8460N All-In-One Printer
I have an canon pixma mp480 connected to a windows xp home computer. It work fine. I shared the pinter to the network. I got the windows xp connected to that shared printer, but the windows vista computers...
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Jun 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Just got a new printer Brother MFC-5860CN
i think you need th software you can download it from main download section its in support.brother.com
Apr 01, 2009 | Brother Multi-Function Center MFC-5860CN...
Brother hl2070n
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Brother HL-2070N Laser Printer
Connecting printer to SBS (Small Business Server)
You can physically connect the printers to the server and share it from there or leave the printers connected to your computer and have the server connect to them via a Local Port which routes to your computer!! To do the Create the local ports you'll need to 1.) share the printers on your pc 2.) Go to the server and go to printers in control panel 3.)Click on Add a new printer then next 4.)Select Local Printer connected to this computer; De-select Automatically Detect Printer 5.)Select Create new port and select Local Port 6.)In the enter a port name, enter the full network path to the printer i.e. \\your-pc-name\printer-share-name click ok 7.) Select the drivers for that specific printer(if its not there click on have disk then browse to the drivers to install them) 8.) Continue through the installation until finish) 9.) Repeat steps for additional printers Keep in mind that your computer still needs to be on! You can check to see if your printer support a network card to make them fully network printer you can add them to the server this way and only the server would need to be on! Or you can also get a print server(Device that makes regular printers into network printers). Now when it comes to the scanning, i don't know of any way to share a scanner with just windows alone, but there are third party software that allows you to do that Check out http://www.remote-scan.com/ There are also printers that sorta do the scanners sharing by automatically scanning and putting files in a designated area on the network! Hope this was helpful regards, babb
May 02, 2007 | Canon LaserBase MF5650 All-In-One Printer
120 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
