Question about Intel D865PERL Motherboard
D865 Perl with 80 gb sata plus 1024X2 400Mhz DDR Ram
I have a motherboard d865perl,i replace the hardrive(IDE to Sata),and memory(before 2 nos of 512,now 2nos of 1 gb) after this my board is restart continuously.
    Sergeant:
    Champion:
  • 293 Answers
-check your reset button if its not stucked. -else try resetting your CMOS settings to default. -try using your old memory sticks.
Posted on Sep 13, 2007
Dear i am using ms-7142 v-1 motherboard. now i,m using ide 80 gb hdd.now i want to connect 160 gb sata hdd.its not showing bios also.hdd is working fine.i reinstalled os.and installed sata raid driver
first thing I would try is seeing if the sata drive is recognised on another motherboard if at all possible ,in order to eliminate the motherboard as the issue.If it is recognised on a different motherboard it is more than likeley a bad cable or a bad board .
Sep 23, 2014 | Computers & Internet
Computer doesn't boot 'no boot device available" it cant find the hardrive it says sata 0-none sata 1-none sata 3-none sata...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 17, 2011 | Dell (Y3392) 80 GB SATA Hard Drive
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Hi I want to put a new hard disk in my computer which has a ms8147C+v1.0 motherboard. Can you tell me which hard disk would be compatable - i am looking at Seagate also how much ram can i install?
Hello.
About the ram memory: it can support 3 slots of DDR SDRAM memory of 1 GB each (maximum). So, the maximum supported memory is 3 GB. And now, about the hard disk: you need to buy an IDE hard disk because SATA is not supported. So, when you go to the store to buy a new hard disk, ask for an IDE one.
Cheers!
Feb 27, 2010 | Matsonic Computers & Internet
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
How much Hard disk my motherboard D845GVSR will support.
There's not really a limit to how big a harddisk you can support. The only thing that can restrict you is the connection, because, for obvious reasons, you can't connect a SATA disk to an old IDE board, but it seems like you're aware of that.
You can just buy any SATA HDD you want!
May 13, 2009 | Intel D845GVSR Motherboard
Sata Hard disk and DDR 1Gb Ram not supporting to my motherboard how can i add and detects this both things please give me reply as soon as possible
Do you have a SATA Cable for your SATA hard disk?
What are the spec's for your RAM, it should be 2 x 184 pin DMMs, 400 MHz, 333 MHz,266 MHz memory. up to 2 GB Ram.
Jan 23, 2009 | Mercury KVM800M Motherboard
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
Intel D865PERL Motherboard Logo
128 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
