Question about Dryers
Whirlpool electric dryer. Clothes stay soaking wet after an hour. Dryer heats ok, clothes tumble, vent is clean. filter light flashing.Fuse was replaced along with thermostat.
  • Anonymous Apr 14, 2009
    Dryer runs for an hour or more and still clothes are damp or wet.
You were absolutely right about it being a venting issue. Although we thought we had it all cleaned out there was still a ball of lint blocking the air flow and causing the problem.
Thanks for your help.
Clint
Posted on Apr 15, 2009
My Whirlpool AWZ233 clothes dryer keeps stopping before the clothes are dry.
check vent line and or clean vent line inside dryer, clean vent line. Felt is probably drum seal.
Whirlpool AWZ233 Tumble Dryer Parts
Apr 20, 2018 | Whirlpool Washing Machines
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
I've got a zaussi tce7276w condensing tumble dryer and its taking 3-4 hours to dry a load of clothes it doesn't seem to be getting hot inside i've cleaned all the filters and checked the back for blockages...
yu may have a bad heat switch but it sure sounds like ur dryer vent is kinked or clogged double check better yet unhook it from the back of the dryer and dry a load of clothes if better ur problem is in that vent
Feb 24, 2010 | Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Dryer wont dry my clothes
Your heating element is not working. The element could be burnt out or the high temperature switch is bad.
May 29, 2009 | Dryers
Not drying clothes
If the unit is heating properly which it should pull around 25 amps when heating , and the unit is tumbling it is 100% an exhaust issue , either a kinked duct behind the unit , a ball of lint stuck in the duct , lint build up outside in vent , or water in under ground duct. If you find the clog it will be FIXED!
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Whirlpool WED6200S Electric Dryer
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Dryers Logo
251 people viewed this question
Top Dryers Experts
