Question about Dell Inspiron 6400 Notebook
Media Center-"No tuner installed"
Hi Recently I bought Toshiba Qosmio F25-AV205 with Win Pro MCE installed. I have problem watching TV with the Media Center because doesn't recognise the TV tuner card (message: -"No tuner installed") even though I have installed the latest TV tuner drivers fro Toshiba. It's odd because other players including Qosmio run without any problem with the same tuner(I guess). I downloaded all the downloads for Win MCE from Microsoft but when I tried to install them appeared that they are not for the same version of OS. Please help me because I am very confused and don't know what to do? Thanks. I get the same Media Center message, "No Tuner Installed," but it was right after a power and cable outage in my vicinity. Before that, everything worked perfectly. 'Worried that it may be motherboard damage from the outage, or spiking when power returned... Also, my external mouse stopped working...
  • 2 more comments
  • quarterStar Apr 14, 2009
    My problem was added to someone else's slightly different tuner problem above.
    Dell Inspiron 6400 Notebook:
    - quarterStar
    Thank you, Dageezer. Since I posted the comment, however, I've discovered my printer connection has also been affected; I cannot get it to communicate with my laptop.
    Printer, mouse, TV tuner... All three have failed, you think, as a result of the outage???
    All I can $$$say i$ ...ouch!.
  • quarterStar May 02, 2009
    Update:
    'Had to replace the motherboard. Afterwards, the TV tuner worked perfectly. The mouse didn't and communication with my printer is still kaput...
    Dageezer, this was a misunderstanding...
    I was the SECOND poster (Dell Inspiron 6400) with the same error message "No tuner installed." as the first poster who owns a Toshiba. For some weird techie reason, the Fixya system attached my message to "Toshiba's" and replaced his/her user name with mine, quarterStar. When I noticed the glitch, I re-posted with an explanation. (If you read the Toshiba post again, you'll see that IT ends with "Thanks" and the next line begins MY post, then my duplicate post follows.)
    I assumed that since I had presented my problem -- and an explanation of the conflation -- along with "Toshiba's," you were responding to both of us. Of course, as you've now indicated, you could not have been including my issue because I clearly stated my other device failure, my mouse, in my initial post and later the same day when I discovered my printer prob., came back and added that info, as well.
    You thought I was "Toshiba." I thought you were wrong. Big mess. Maybe Fixya can fix ya rating.
  • 3,940 Answers
It sounds like the TV tuner card has failed, and will need to be replaced
Posted on Apr 14, 2009
  • IQUIT May 02, 2009
    It was a failure of the slot the tuner was in, still a hardware failure. If you'd mentioned the other devices had failed, then my answer would have been different. But I do believe an Inappropiate rating is a bit harsh, baseed on the original information you provided.
I can't log on to the internet on my Toshiba Qosmio F25-av205 laptop. It is asking me to turn on the wireless communication switch. I can't find the switch. Please help me. Thank you.
look on the right side of the laptop at the bottom of those indicator lights. try to slide and check if connection will be there.
thanks
Mar 28, 2014 | Toshiba Qosmio F25-AV205 Notebook
I need a recovery cd for my F25-AV205. Toshiba says it it no longer available
This is pretty much the only way to get a recovery cd for this laptop:
http://www.ebay.com/sch/i.html?_nkw=Toshiba+Qosmio+F25-AV205+recovery&_sacat=0&_odkw=Toshiba+Qosmio+F25-AV205&_osacat=0&_trksid=p3286.c0.m270.l1313
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
Sep 11, 2011 | Toshiba Qosmio F25-AV205 Notebook
How do you reconnect wireless network connections on toshiba qosmio f25-av205 using windows xp have drivers but the wizard says diconnected
Ok, first you want to right click on my computer, select manage, services, and double click on wireless zero configuration and select automatically under startup type and click on start. Double click on the icon for the wireless zero configuration next to the clock. Select the correct wireless connection and click connect.
May 17, 2010 | Toshiba Qosmio F25-AV205 Notebook
I have a Toshiba Qosmio F25-AV205 Notebook that operates correctly under battery power. When connected with AC power sometimes it will work for awhile, and others it just turns off and a yellow diode on...
The power supply is failing and cannot provide the necessary power to charge and run the computer. You'll need to search the internet for a replacement power supply. You can potentially damage the computer if you continue to try to operate it like this.
May 12, 2010 | Toshiba Qosmio F25-AV205 Notebook
I have a Toshiba Qosmio F25-AV205 laptop and when I turn it on it states "CD-ROM ERROR" and I need the cd drive to load an OS on the hard drive. I know that toshiba's need to be set to slave but even if I...
what you need to do is try restarting the system and press and hold press and hold F8 keyit will take you to system restore. then you can select from options with different dates back. it will now restore the system to the last best known state.
Jan 22, 2010 | Toshiba Qosmio F25-AV205 Notebook
Want to change a cracked screen on the qosmio f25... how do i do it?
Go to this page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1021512&rpn=PQF20U&mpn=&modelFilter=F25-AV205&selCategory=3&selFamily=804517
Then click on Maintenance Manual and go to page 4-56 and read on about how to replace the LCD.
Aug 15, 2009 | Toshiba Qosmio F25-AV205 Notebook
Open up a toshiba qosmio f25 av205
http://www.irisvista.com/
This site has free info and Pic to open up the laptop.
one screw is hidden under monitor cable.
look up replace video card.
Ckreuzer
Dec 26, 2008 | Toshiba Qosmio F25-AV205 Notebook
Toshiba manual
This site has free instructions and photos of a large number of laptops.
just used them to dismantle my toshiba f25.
Key word FREE.
Ckreuzer
Sep 01, 2008 | Toshiba Qosmio F25-AV205 Notebook
Dell Inspiron 6400 Notebook Logo
483 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
