Question about Microsoft Windows XP Professional
Syntax error on Boot Up
I have a Windows XP machine and when booting up it says it has a Syntax error and will not continue. Any ideas on what this might be?
  • nelson1707 Apr 15, 2009
    Wow, thank you all for your promopt responses. The computer was a friend's and the Syntax they were referring to was the manufacturer of their motherboard, Syntax. I heard syntax and thought immediately that it was a syntax error. Their hard drive was going out and so it hung on the post screen. Thanks again!
  • Rahul Panicker May 11, 2010
    Can you elaborate the error message.
    syntax error {....)
  • 326 Answers
Attempt to boot the machine in Safe-Mode.
While powering up continuously hit F8.
You will get a Boot Option Menu
Select Safe-Mode boot
Often times drivers, or system files may be "lost" or referenced wrong, and booting into safe-mode can solve the issues, sometimes.
Check in the Device Manager for any conflicts if you are able to get into Safe-Mode.
Note any Red X or ! symbols near any devices and their names. You will have to reinstall the drivers for these devices. Consult the machines manufacturer website for downloads and support for any devices listed.
Let us know the results.
Good Luck
Posted on Apr 14, 2009
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
    Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    Try replacing the IDE cable cable if you suspect it might be faulty.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
I have no idea if I'm even in the right ball park, but anyways, I have a Pentium 4 3.0 Ghz laptop that on the top cover says Syntax, on the bottom it says Model No. GREEN736 Serial No....
Going from No wifi connection to reinstalling windows is a big difference in time and maybe documents. If your sure you can't boot and want to reinstall xp the best would be to go into your bios. Its F12 or whatever on your machine just so you get to the bios. There you can select a certain amount of memory that you have to be partioned. Simply all would go for your xp installation. With the xp disk in the drive turn on the machine and it should boot to the installation. If it doesn't your boot order is incorrect meaning the machine is trying to boot from the hard drive and you want the machine to boot from your dvd drive. So in the bios you have to make sure the default boot at least temporarily is the dvd drive. When in the bios that is real simple to change.
With the computer instructed to boot from dvd drive and disc in the dvd drive it will jump to the installation of the xp pro. If you have any questions come back with another and you should get a response as this is a fairly common question
Apr 06, 2011 | Syntax Computers & Internet
How to set up dual boot for two hard drives?
My freind, you can boot from two hdd inside the same computer. You can only boot from the primary HDD. What you need to do is install both Windows 7 and XP on the primary hdd in different partitions. Then when you boot the system it will give you the option for booting to both XP and 7. You dont even need the secondary hdd unless you are looking to have more storage space.
May 04, 2010 | Computers & Internet
Samsung r40 not loading xp
If the computer boots in to safe mode fine, you more than likely have a virus or spyware interfering with the boot process.
Windows also could have corruption on it.
Insert your windows XP CD and boot the computer, you may need to set your boot order in BIOS so tht CD is first.
Once the CD loads Run the recovery console Select 1 for the C: drive if it asks for a password this is generally blank or will be the password on the "Administrator" account you see when you boot to windows in safemode
Once in the recovery console do a chkdsk /f command
This is will check for errors on the disk and can fix a lot of boot issues
I would also suggest typing the command mbrfix to replace the master boot record.
If it still will not boot you may need to reinstall windows xp
Nov 02, 2009 | Computers & Internet
So, I'm in the middle of playing guitar hero 3 on my computer, then I get a blue screen. I reboot, and I get a bluescreen, rinse repeat. Long behold, I probably have a boot sector virus. So, I grab my xp...
As you are accessing the internet you must have another computer. If so, remove your hard drive install as slave in the other machine backup your data and reformat. If you do't have another machine maybe a friend could help.
Oct 30, 2009 | Microsoft Windows XP Professional SP2
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
Shuts self off during start up
Sounds like there could be a major problem with the hard drive.
Have you got an XP or Vista cd? NOT a restore cd.
Mar 10, 2009 | Acer Aspire 5610-4648 Notebook
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Computer wont boot up
hi, If it is a continuous beep then it a RAM error not a harddrive, so you try to change the ram slot if it doesn't happen change the ram thanks arun
Sep 04, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Microsoft Windows XP Professional Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
