Question about Siemens Dishwashers
Lower Spray Arm doesn't Rotate on Siemens SE55A560 Dishwater
Hi,The lower spray arm in my Siemens SE55A560 dishwater doesn't rotate. Seems like it doesn't get enough water pressure. The upper spray arm works just fine.Please HELP!!! Thanks, Ophir
  • 3 more comments
  •  Ophir Baer
    Ophir Baer Apr 14, 2009
    Thanks for the fast response.
    It is not obstructed by anything. The spray arm can rotate easily when I check it. It's also completely clean.
    I know it doesn't rotate, because I put it in a certain angle and no matter how long the program works, it stays in the exact same position (while the upper arm changes position).
  •  Ophir Baer
    The ones in the upper tray are clean - yes - worked by the upper spray arm.
    The ones facing down on the lower tray - not really.
    Lower spray arm doesn't rotate and possibly doesn't get enough water.
    Could it be a matter of a missing rubber ring? Because when you pull out the lower spray arm (as instructed in the manual) you don't see any rubber ring to possibly keep the water from getting out in the wrong place. Just a speculation, because I can't really see what goes on there when it's working.
  •  Ophir Baer
    Ophir Baer Apr 15, 2009
    I'll check with the Service to find out if this is really the issue.
    Thanks for your help and support.
  • astrid prieto May 11, 2010
    Dishes etc, clean?
    It is not obstructed by anything?
    How do you know it does not rotate, warning light?
  • 297 Answers
Upper and lower connection should be same type of setup
missing part thus?
This sometimes is also caused by not driving in right the rack (closing properly) mating the connections tight. My old Bauknecht had this little problem.
Unfortunately I have no manual with parts drawings.
Still warranty?
Parts shop nearby?
Upper connection does have rubber ring or is a conical seal?
And when you fill the basket, no teaspones or such dropping too far down? My error many times.........
Posted on Apr 14, 2009
  • astrid prieto May 26, 2010
    you uploaded the video on youtube?
  • 4 Answers
I have a similar problem, possibly with a different model, but there is NO water at all entering the bottom spray arm. i'm going to video my machine's interior to work out if water is coming out of the pipe. fingers crossed.
Posted on Aug 07, 2009
My Lamona dishwasher HJA 8650 lower spray arm wont rotate, water is spyaying out and nothing in place to stop it rotating, can you help?
Sounds like the pump that pushes the water up to the spray arm is going south on you.
Check to see if the pump or any of the piping, or sprayer arm jets are clogged.
Feb 23, 2017 | Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
How do you fix a leaking problem in the front of the Whirlpool dishwater, model DU941PWKQ1?
Wipe the crud off the gaskets around the inside where the door touches
Jan 10, 2014 | Dishwashers
My Amana Softsound 2 isn't getting dishes clean - the lower arm doesn't rotate. We cleaned around and under the arm as much as possible, got some gunk out from under, but still not rotating, so...
Check the nozzles of the arm themselves. if you found lots of gookl there maybe some inside the arms blocking the spray holes which cause it to spin
Jul 15, 2011 | Amana ADW862EA Built-in Dishwasher
The bottom washer arm does not turn or squirt water
Hi Matt.
The lower housing underneath the lower wash arm may still have something blocking the water passages.
If the spray arm is clean and it freely rotates try lightly pressing down on the wash arm and then rotate it. Your checking to see that when water is applied to the spray arm it forces the arm down against the lower housing tower and hopefully does not lock up. If it does lock up while pressing down and rotating obviously you need to find out what the cause is.
You may have to remove the lower wash arm housing and clear the debris from the water passages. Once the passages are clear it should work fine.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Viking DFUD042 Built-in Dishwasher
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Upper Spray arms not spraying
Took apart again and found the stepping motor which diverts the water from lower to upper spray arms to be burnt out. I was able to manually set the diverter to the correct position so the dishwasher works but I am waiting for new parts to properly repair the problem.
Oct 09, 2009 | LG LDF6810ST Stainless Steel Built-in...
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwashers Logo
490 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
