Question about Swan Home
Cold tap doesnt work
Trying to dismantle cold tap so i can replace with new washers - can anyone help me? thank you :)
  • 74 Answers
Is it a single handle or double handle faucet?
If it is a single:    1.  Remove handle via setscrew the side of the handle          (possibly under a decorative cap with the company name)    2.  Unscrew the packing nut holding the valve cartridge in    3.  Remove cartridge and access washers
For double handle    1.  Remove decorative cap on top of handle with a think screw driver.    2.  Remove handle and packing nut holding the valve stem in place    3.  Remove valve stem and body to access washers and o-rings.
Remember to turn water off at the source prior to doing any work. Replacement is just reverse of removal and don't forget to use a washer grease on all washers/o-rings when reassembling.
Posted on Apr 14, 2009
Washer not filling with water
Hi Karen. Problem may be the internal "tap" that operates electrically. First test - If you are trying for a cold wash, try a hot wash. If maching begins to fill you know this tap is your problem. There are 3 solutions if this is the case
1) swap hot and cold water hoses at the tap and tell machine to do a hot wash - only good if you only want cold washes
2) check where hoses connect to machine at rear - sometimes a fine mesh filter that has become clogged - may be at either end.
3) Replace the internal "tap"(solinoid). This "tap" has a rubber diaphram inside that may become stuck if the machine has not been used for a while. it can be easily dismantled and reasembled by a handyman.
Apr 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
24460 washer just installed but water will not come in when press start , 86630 dryer works fine .
(Although you say that the washer is 'just installed', you do not say whether it is new or not)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve.
If the washer is new contact the vendor!!! I assume it is still under some sort of guarantee/warantee? You can nulify any guarantee if you attempt to fix problem before contacting vendor.
If it is not new you will need a service call, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 15, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Hi, i had plugged in my new Stirling washing machine and the hot water is working but not the cold water. It seems something is blocking it. Can anyone help. Thanks
Carry out these (pre-typed for hot and cold!) steps before contacting the manufacturer's service centre or your vendor.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call.
John C
Sep 12, 2011 | Washing Machines
Alarm F10 is displyed , my washer/dryer doesnt
Hotpoint error code F10 is
"No cold fill. Check that the taps are on or if the drain hoses are kinked".
Has someone turned off the water supply or the isolator valve on the plumbing?
If not, you may have a faulty inlet valve on the machine.
Please drop a comment back on this thread if you require further help or guidance
Jul 21, 2011 | Hotpoint Washing Machines
I have a beko washing machine it doesnt work when i check it i find there is no water in it after i turn it on and it cycle then it is stopd in 27 min and it doesnt work i made eveything but nothing happen...
No water fill?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jul 08, 2011 | Washing Machines
Washer buzzes when we select any cycle and doesnt continue. We have cleaned everything and tried every cycle with the same result
Unfortunately you have not told us the make and model of your washer ;-0( However-
John C
Jun 19, 2011 | Washing Machines
Haier Genesis HLT364XXQ CAN'T GET HOT WATER WASH
hey Paul, you don't have to wash anything in hot water. Hot water only wastes money and does nothing, in my opinion, to get anything cleaner. It does ,however set the stains. To kill any thing the water has to be 212 degrees [ boiling ]I have not used hot water for over 40 years and our clothes are coming out clean. Just set the machine on cold. I put a twoway spigot on my cold tap and put the hot water and cold water together incase someone breaks in and does my laundry. Barry
Feb 14, 2009 | Haier HLT364XXQ
Cold water only very slowly trickles into the washer. Hot water works fine. Cold water has very good pressure and volume at all other sources in the house. The cold water hose at back of washer is clean...
there can be 3 reasons for this I will tell u the easiest way to test this first
Problem1)turn the water off at the blue tap fitting that is proberbly under your sink take the blue pipe off at the washer end and place it into the sink turn the blue tap back on if the water comes out quick then the problem is more then likely your cold water solenoid that is either slightly blocked were it fits to the washer,But if it doesnt come out quick then the other 2 problems are as follows.
Problem2)the blue tap that u turn the cold water on to the blue pipe undue the little screw in the middle of the tap and pull the blue fitting off now with a pair of pliers turn the square metal fitting that was under the blue fitting making sure that the end of the pipe is in the sink if it comes out quick then that is the problem the blue tap fitting is rounded off when ot should be square turn the water of and replace the pipe and turn the water back on the cold water should be better now.
Problem3)the blue tap that u turn the cold water pipe of at the copper pipe is blocked or it has a broken shut off valve inside it this will need replacing these are the only problems that it could be let me know if this is any help to u peter
Jun 09, 2008 | Whirlpool Washing Machines
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Home Logo
395 people viewed this question
Top Swan Home Experts
Donni Steen
Tom Chichester
Are you a Swan Home Expert? Answer questions, earn points and help others
