Question about Magellan eXplorist 500 GPS Receiver
Zoom in and out buttons not working properly
In order to make the zoom buttons work I have to press them very deep. The situation is getting worst, now the zoom in is not even working any more.
  • COMCONSOLUTI Nov 23, 2008
    zoom in button not working ..zoom out worked ok all way out won't come back in not an over used unit shouldnt be a wear and tear issue have had apart contacts all seem fine HELP !!!!!!!!!!!!
Mine does the same. I find if I tap press on the in button it works better. My out button works fine.
Posted on Nov 05, 2009
    Problem Solver:
  • 7 Answers
Unfortunately, this is a problem with the keys and their contacts with the circuit board. I have had to return mine a couple of times to get this repaired. If you're out of warranty, they have a trade-up program which is a better deal than repairing the unit.
Posted on Nov 07, 2007
    Problem Solver:
  • 4 Answers
After NOT using a similar Explorist 300 for a year, I found that a Zoom button and the NAV button do not work, because of no contact below the keyboard. I can get around the NAV problem using the ESC key. Force and luck occasionally cause the Zoom key to work.
My guess is that a plastic bubble wears out after repeated use.
It's probably not worth fixing but it would be nice to be able to replace the bubble contacts.
Posted on Jan 14, 2008
SOURCE:
When I zoom in to take a picture I get it focused I hit the button and the picture shows up not zoomed?
How are you zooming in? If you are using a button to zoom, that is to check the focus: it's just enlarging the image for your convenience during focusing. In order to get a zoomed-in image when press the shutter button, you need to adjust the zoom ring manually on the lens barrel before taking the picture.
Sep 24, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Remote doesn't work properly
ON THE TOP OF TOUR REMOTE IS SITUATED A INFERAD LIGHT. USE A DIGITAL CAMERA OR A MOBILE CAMERA PHONE TO VIEW THE INFERAD LIGHT. ON THE REMOTE. INORDER TO SEE THE LIGHT WORK PRESS ANY BUTTON ON REMOTE AND YOU SHOULD SEE A LIGHT FLASH EAC H TIME THE BUTTON IS PRESSED. IF YOU DONT GET A LIGHT CLEARLY ITS NOT EVEN TRANSMITTING. ALTERNATE WAY BUY A UNIVERSAL REMOTE AND CODE IT.
Sep 15, 2013 | Bose Audio Players & Recorders
Jvc 57 inch tv. kid did something to change picture size. now too large and bottom is cut off. aspect button on remote when pressed shows a red circle with a line through it.
what was pressed on the remote is "Zoom" button, that's why the picture size is large.
So try to identify the Zoom button on your remote by pressing every button on your remote in order to get the zoom button function.
I hope you understand my message.
Good luck.
Apr 13, 2010 | JVC AV-28-BD-5-Bl 28" TV
I cant get left trigger to work without pressing really hard,help
The plastic inside may have snapped a little and therefore not long enough to properly reach the little button on the logic board, shake the ds a bit and listen out for any ratling noises. The button might not be centred properly, worst case is that the button on the logic board may have a dry joint and is coming slightly loose.
Jan 06, 2010 | Nintendo DS Lite Console
External buttons not working and battery acting up
Same with me! My OK and # buttons constantly stop working X-X I just have to hold them down, keep hitting them, or hit them with another button. But usually Ill have to open the phone.
May 29, 2009 | Verizon Communications enV2 Cellular Phone
Our Cinema series 32" TV is stuck on ZOOM and I can't get it back to regular. There is a ZOOM button but it doesn't seem to do anything. Ted Thank you
unplug tv for five minutes then return plug....now press and hold the tv power button for ten seconds(This should reset it!)
Dec 22, 2008 | Televison & Video
Re- fuji finepix s5000 digital camera
when the camera is turned on the screen says zoom error and whem pressing the zoom button the camera makes a noise and the lens does not move
Oct 12, 2008 | Fuji FinePix S5000 Digital Camera
Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
Aug 07, 2008 | Canon Speedlite 430EX TTL Flash
Creda W120VW washing machine - Energy & Deep Rinse Buttons. How do they work?
I found the manual on a website which I didn't note down, but which was very useful as it had almost every washing machine manual on the planet! Now I know that the energay saving and deep rinsing buttons are activated by pressing them in. Thanks anyhow for your attempt to help!
Apr 24, 2008 | Creda W120VW Front Load Washer
Telephoto images
The D-630 has a 3x optical zoom and a 4x seamless digital zoom. In order to use the digital zoom, press the OK/MENU button on the back of the camera. Press the right arrow key to access the Mode Menu. The first setting under the CAMERA tab is DIGITAL ZOOM. Press the right arrow key to highlight this setting and then press again to select ON. Press the OK/MENU button to set the DIGITAL ZOOM to remain ON. When you press the zoom button with the T on it, a zoom indicator will display on the right side of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. When the zoom indicator is in the red zone, you are using the digital portion of the zoom. images taken in the digital zoom will appear “noisy” or “grainy” which is normal when using the DIGITAL ZOOM.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Magellan eXplorist 500 GPS Receiver Logo
260 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
