posted by hoco on Sep 13, 2007
I watched a burnt DVD and it played fine, but now the drive won't open. It says no disk when I try to open it, but if I hit play it will play. Ideas???
1 Other User Has The Same Problem
Comment by Guest, posted on May 13, 2008
I have the same problem my RCA DRC8052n does not open all the time. either from the remote or pushing the button on the front. This happens everytime we play a DVD, which mean I have to power it off everytime
Best Solution
posted on Sep 13, 2007
straighten out a paper clip & push it into the hole near the bottom left of the tray it will manually push the tray out - reboot & it will probably work again - probably is stressed
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Try this trick. it worked for me. Using a credit card insert it into the Tray opening to remove the front cover of the CD loader. then using 2 fingers push the tray inwards while pressing the eject button. Do this 3 to 5 times. If this does not fix your problem. Send it for repairs.
Suggest a new solution for this problem
Post a New problem for RCA DRC8052N DVD Recorder
Email this problem
Email this problem
Can you Help with these DVD Players problems?
Remote doesn't work, had played...
rca drc8052n dvd recorder &... Answer This...
Repair Service
Find DVD Player Repairman Near You:
Find Parts
