Question about Kodak ESP 5 Printer
I Filled Kodak ESP5 Ink Cartridge, but error remains
Error states that color ink cartridge needs replacing.
Replace Color Ink Cartridge.
Cannot get past this error.
Do I need to reset something?
  • mnsky Sep 29, 2009
    Kodak support claims you cannot "REFILL" ink cartridges. Must purchase NEW cartridge.
  • 295 Answers
Try to reseat the cartridge 2-3 times. probably the carrtidge is defective. call kodak @ 1800 421 6699 and they will replace the cartridge for you free of cost.
Posted on Sep 21, 2009
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
How do I replace the ink cartridge when it will not center when I lift the lid
Since you are not able to find the carriage ( which holds the cartridges ) in center position, Try to move the carriage manually to center. Make sure the printer is On or you can turn it off and move it to center and replace the cartridges.
Also, follow the steps given below as well.
  1. Remove the color ink cartridge.
    • Open the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
    • Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
      IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to Kodak's Web site, then to KODAK Store.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    • Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    • Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    • Reinstall the ink cartridge.
  3. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
If the error condition continues, power cycle the printer:
  1. Turn off the printer.
  2. Disconnect the power cord from the back of the printer.
  3. Wait five seconds.
  4. Connect the power cord to the printer.
  5. Turn on the printer.
If the error is resolved, upgrade the firmware for your printer:
  1. Locate and select the firmware download for your printer.
If the error continues,try contacting the Kodak Tech support by clicking on contact us.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 26, 2010 | Kodak ESP5250 All-In-One InkJet Printer
Kodak 5350 Color Ink Error Problem Solved
Yes the cartridges of all newer printers have chip that indicates the cart ink level, when the cart is empty the chip self destructs.
May 04, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP5 new cartridge error msg: cartridge needs replaced
Try using a new pack of ink cartridges.
If still face the same issue, conntact Kodak support.
They will send you ink cartridges, if still the same issue persists the printer will be replaced.
Dec 20, 2009 | Kodak ESP 5 Printer
Wont except aftermarket printer cartridge error code "not recognized"
May be the cartridge is not detected by Kodak printer. Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges.The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 23, 2009 | Kodak ESP 5 Printer
Black ink is faded
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Mar 29, 2009 | Kodak ESP 5 Printer
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5300 will not accept the new ink cartridges
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 color ink error
OK so i found some new information that should solve the problem. The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK CARTRIDGE2.gif EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error. So to fix your problem First Remove the ink cartridges and download and install the new Firmware. Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimburstment of some sort like a free set of ink tanks.
Jan 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Color, black ink cartridge error
contact epson support
they may replace your cartridge
Oct 24, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Kodak ESP 5 Printer Logo
2,355 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
