Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Manual oiler on Poulan 3400 does not work. Is ther an oil line, if so wher is it located? This is an older model 3400 Countervibe chainsaw
  • leg45 Apr 16, 2009
    I have already cleaned out the oil tube hole. I was hoping yopu could tell e if ther is an oil line that might be broken
  • 666 Answers
SOURCE: I have inheirited a Poulan counter vibe 3400 it
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem poulan then poulan then saw then look at list of models you will find 3400. Have worked on one or two of the 3400 and they seem to be a fairly good saw for home use.
Posted on Apr 07, 2009
Fog Horn
  • 17 Answers
SOURCE: Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
Posted on May 26, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan chainsaw repair manual
What you request to the best of my knowledge does not exist. You may find this helpful. Had you provided a model and serial number it would have been more helpful.
Typical fuel system and couple of suggestions:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL for you saw can be found here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If I can be of further assistance you can reply below. I hope you found this most helpful.
Lou
Posted on Jan 30, 2010
dontbother10
  • 2220 Answers
SOURCE: lost my manual for my poulan pro 255 chainsaw the
If looking for parts your OM is of little value. You can find an IPL (exploded parts list) here (only one PP255 listed):
http://www.ordertree.com/modelinfo/PWE/PP255-Gas-Saw/75.PP255-Gas-Saw.1.59.1.html
Rear vibration (isolation spring)s appear to be item 5 or 59 on the "Exterior Assembly" print.
Poulan replacement OM.
http://72.3.225.179/manuals/87722e.pdf
There is contact us number in the OM if you want to contact Poulan. HTH
Lou
Posted on Feb 15, 2010
Testimonial: "thank you very much for the information that you sent me. i spent two hours on a dial up modem trying to find the part and 20 seconds to read your rep"
jrox55
  • 66 Answers
SOURCE: poulan pro 220 chainsaw owner's manual for tune-up
you could try cleaning the carb and filter. make sure your fuel lines are clean too
Posted on Feb 27, 2010
Poulan 1950 woodshark
The first thing I would look for are cracks in the oiler lines. If the saw has a manual oiler try to see if that will get oil to the chain. Check to see if the cap on the oil tank has a plugged vent hole.
Aug 30, 2013 | Garden
Do you have an owners amnual for a 1983 Poulan Countervibe 3400 chainsaw?
Follow this LINK. If it doesn't work, let me know. I know it says Husqvarna, but that is because Husqvarna owns Poulan, but this is a poulan manual.
Mar 07, 2011 | Garden
Poulan Countervibe 3400 will not start
In all of those years, the fuel and oil lines will have deteriorated as well as the rubber components in the carburetor. The fuel filter in the tank is probably also plugged. Remove the spark plug and check for spark--it should be blue and snappy. Check the condition of the primer bulb--it should be soft without holes or cracks. Try some fuel in the cylinder head and reinstall the plug. It should pop a few times if in firing condition. Replace the air cleaner and check the muffler for plugging. Pretty much a major tune up! Hope this helps!
May 22, 2010 | Garden
Automatic chain oil leaks oil?
possible crack in the reservoir, or line has come loose
Feb 05, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oiler on saw not pushing oil as fast as gas is there an ajustment screw or is it automatic and just needs to be cleaned
Your Operator's Manual does not address any oiler adjustment; an IPL for for your saw lists no oil adjustment screw.
Operator’s Manual
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006-PP4620AVX-952802146.pdf
IPL
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AV-545014314-952802075.pdf
Given the above I would conclude your saw has no operator adjustable oiler. If you think oil output is inadequate contact Poulan here:
Poulan.com
http://www.poulanpro.com/node4033.aspx or phone them
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1 (800) 554-6723 (Please have your saw within easy reach)
HTH
Lou
A shorter bar will oil better. with no adjuster I recommend you not go longer. If the bar is getting hot make Poulan repair it under warranty!!!
Nov 17, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan Pro 380 that is leaking bar oil.I can fill it with oil and it will leak out during the night.
I have 7 chainsaws. 6 of them if I forget to drain the oil reservoir will oil the surface of what they are sitting on. What you are seeing is normal.
IMO; use of the oiler creates a siphon. Any oil left in the tank will continue to siphon until the reservoir is empty. I could be wrong, I have been before.
Draining the tank works, nothing else I've tried does. HTH
Lou
Nov 06, 2009 | Poulan Pro Chain Saw 46cc 20"
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Apr 07, 2009 | Poulan Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
503 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
