Question about Orion1934 19" TV
Problem i had a speaker by the tv didn't know it was pulling the color is there anyway 2 pull it back 2 normal?
    Novelist:
    Champion:
  • 275 Answers
Hi Ginger, The Magnet in the speaker has affected the Electrons beams inside the TV.All uou gotta do is remove the speaker - move it to around 3-5 feet away. Use the TV normally. Most Colour TVs have an in built de-gaussing unit inside them, which will clear any remnanrmagnestism. Will resolve itself over 2-3 days. Alternately, go to a Electronic Tools store, and buy a Portable Degaussing unit. Follow instructions and use. Problem will be solved in minutes.
Posted on Apr 15, 2009
Samsung plasma tv
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 07, 2016 | Samsung Televison & Video
How do I get a good running stitch?
Not specific to your machine - a secret to easier gathering is to drop the tension on the upper thread by 1 or 2 numbers before sewing that gathering line. Then, you pull the bobbin thread when you gather. It will gather MUCH easier. Just don't forget to put the tension back to normal before you start regular sewing again! Temporarily switch to another color bobbin if you're afraid you might forget which is which - you'll be pulling it out anyway. I think most people gather with a stitch that is just .5 mm longer than they're using for construction.
Mar 24, 2015 | Janome Harmony 2041
How can I replace a tweeter for a 10 year old Cambridge Soundworks tower 2 speaker?
Its pretty simple actually.
If you already have the same size new tweeter. You take off of course the large felt cover so speakers are exposed on front. Just like your picture is in this post. Then you should see some screws, most likely it is going to be Phillips. Then unscrew all the screws, the whole front should slide out with of course speakers still attached, don't pull out to fast or far, to make sure the internal wires are long enough to take whole front out and set aside speaker box, the on back of speaker should be two wires going to it, maybe three if is tapped in conjunction with a ground. Anyway on back of speaker unplug the wire from speaker and then, take out screws which is normally on back of speaker, pull speaker out, put new one in and repeat steps in reverse order. Hope this helps. Mike
Jul 07, 2011 | Cambridge Soundworks Tower II Speaker
My tv is displaying a double picture.. i pulled the back off and covered the red lamp and the picture goes back to normal but no red in the colors.. pull my hand off the red lamp the picture doubles...
Problem cause is red convergence output chip failure that will be replaced to fix the issue.
If you have experience of electronics stuff repair and can replace parts in circuit board as it requires soldering work with proper tools then can replace convergence output IC in your tv by yourself.
Let me know if you have additional question.
Thanks.
May 03, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a Hitachi projection color tv and I cannot get the color adjusted good especially the red. Can you help me?
U know how to solders?Ur convergence it dead,need it replaced parts,by buy convergence kit.Tries Tv repair World.com,Tvrepairkits.com.
Dec 20, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My 2 years old son removed the protective cloth from my B&W 602 speaker and pressed on the metal "gold" color twitter dome and deformed it. Is there anyway that i can bring it back to the original...
I'm sorry but I don't know of any way to pull the dome back out. A speaker specialist might be able to but I know they aren't going to guarantee it. If the dome only has a small dent in it and your ears aren't specially trained you probably won't notice the slight drop in high frequency response. If you do notice the difference I would recommend that you climb into the yellow pages and look for an audio speciality store. You may have to replace the speaker and if the speakers are matched pairs in each cabinet you will have to replace them in pairs to maintain the proper balance.
Thanks,
rich
Sep 26, 2009 | Audio Players & Recorders
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture mode: Custom
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
Dec 26, 2007 | Televison & Video
Orion1934 19" TV Logo
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
