Computers & Internet Logo
Posted on Apr 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lines on my laptop screen
My 17 inch laptop screen displays lines down... and the color has changed
Tom Sutch
Level 2:
  • Expert 48 Answers
  • Posted on Apr 14, 2009
Tom Sutch
Expert
Level 2:
Answers
48
Questions
Helped
20859
Points
131
I have a Toshiba that has done this. Your only option is to have the screen replaced or live with it. You could also hook it up to a desktop monitor when you don't need it to be mobile.
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
1helpful
What size display
Please give more details if you really want help. Displays come in different sizes, 14 inch, 15 inch, 17 inch, etc. You have to buy the size you want.
If you are talking about the size of Text on your screen then you can change it by Clicking Start/Control Panel/Display and select Appearance Tab then go down and change the FONT size. Depending on your operating system the Display might be under Appearance and Personalization.
Verticle lines on the screen
Failing Display Panel Circuit Board... THis Means You Will Need A Screen Replacement..
1helpful
2answers
Large black line at the bottom of the desktop - about one inch wide. Windows opens above the frame of the desktop.
you need to change the aspect ratio or position of the screen using the menu and buttons on the monitor
2answers
Horizontal lines on ASUS laptop screen
HI friend
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is Motherboard problem Please contact Your nearest service centre for Service.
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Need a workable seconds LCD 17'' screen for Compaq
the screen is most likely ok sounds like your power inverter for the screen on the laptop is going out if it is that is a cheep fix compare to replacing the screen a computer rerpair shop that works on laptop should be able to fix that for you
2answers
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
