Question about GE Profile Spectra JGB920SECSS Gas Kitchen Range
Stong gas smell ater oven lights. does not stop
No problem with the top burners
  • 10,865 Answers
You most likely have a gas leak in one of your connections or fittings. go to the hardware store and get a small bottle of gas leak detector. Test each fittinig and even along the pipe to find the leak. Once you have found the leak fix it by tightening the fitting, undoing the fitting and applying pipe dope, etc.
Posted on Apr 14, 2009
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Oven out/flat top has hot spot/burners ticking everywhere
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 11, 2009 | Viking VGRC605-6 Gas Kitchen Range
Mid 90's Magic Chef gas stove
hi there,
since you can smell gas, you have a gas leak. i would recomend checking and cleaning the gas valves. if you can hear sparking, that means it's just the valves. sometimes cleaning the rods will fix the problem.
Oct 10, 2008 | GE JGRP17 Gas Single Oven
GE Profile Spectra JGB920SECSS Gas Kitchen Range Logo
169 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
