Question about Intel D845GVSR Motherboard
No display or no boot
I have dead intel D845GVSR motherboard. When i switched in motherboard led is on cpu cooler fan is spinning, but no display on monitor. i have replced the ram and psu. but problem is same.I suspect the BIOS is currupted. how can i solve problem?
    Problem Solver:
  • 11 Answers
I suggest you flash your bios.
if this doesn't work replace your motherboard...
Posted on Apr 21, 2009
All fans spin very fast. no boot / no display
you could try to check the bios . you would need to open the laptop to see the bio reset pin . if this doesnt work . more thank likely it could be a faulty CPU
Nov 11, 2013 | Intel Corporation Network Servers...
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
FAN OK BUT NO DISPLAY
I like that. Kinda' rhymes. "Fan OK but no Display"
Problem is your Processor isn't turned on.
You have a bad Power Supply.
> Weak voltage power rail.
You probably have a 200 to 300 Watt power supply. (SMPS)
1) ALL of the LED lights together use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 watts. Depends on what Processor it is.
The Intel D845GVSR motherboard uses a Socket 478 processor socket.
Supports Intel Celeron, Intel Pentium 4, and Intel Celeron D, that utilize a Socket 478 processor socket, and have a maximum FSB of 533MHz.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Utilizes the Intel 845GV motherboard chipset.
[ Intel 82845GV Northbridge chip, and Intel ICH4 Southbridge chip ]
89 Watts is the maximum wattage, that can be used by a Processor for the Intel D845GVSR motherboard.
Power Supply has enough power to light LED lights, and spins fans, but not enough to turn the Processor on.
No Processor operating, No computer.
No computer, No video signal to the monitor.
(No Signal)
Do you have access to a KNOWN to be good, compatible Power Supply, for a test unit?
Motherboard Manual in PDF file form:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845gvsr
Under the heading > Documents and Guides, left-click on > Product Guides for D845GVSR.
Then left-click on the first file listed.
Product Guide - PDF File Name: D845GVSR_ProductGuide_English.pdf
Nov 03, 2010 | Intel D845GVSR Motherboard
Fan Speed 100% on Intel D845GVSR motherboard
see if you plug them in the right spot cpu gose by the cpu case fan will say case on board some take two wire fans some 4 wire some 3 wire jim
Feb 20, 2010 | Intel D845GVSR Motherboard
I have a problem with Intel D845GVSR Motherboard with 2.0 GHz processor. When I power the M/B, only the Motherboard LED is on, but no boot, no cpu fan running. No beep code also. I check the SMPS, RAM,...
Think this should be an issue with the power button, Remove the wires running from the power button to MB and try starting the system with shorting the 2 lead of the power button..
Mostly, it can be due to bad power supply or Ram
Rate this solution
RNJ VINODKUMAR
Sep 26, 2009 | Intel D845GVSR Motherboard
Led blinks but fan rotates and stops but pc does not operate and after switching on and off for several times it operates
There is a CD tool called "Ultimate Boot CD" which can be downloadedathttp://www.ultimatebootcd.com. On this CD there are quite a fewtoolsthat you can use to test your RAM, CPU, Hard Drive, etc.. forproblems.Just boot up with this CD and select the corresponding testingprogramto use. Test each component until you find the component causingthe issue.
Cause it seems something is overheating.. Probably the CPU.
Aug 19, 2008 | Intel D845GVSR Motherboard
Circuit diagram
For just a short advise you may buy that kind of circuit in the computer shop ... Just reply me if my advise is helpful or not?
It's ok???
Jul 02, 2008 | Intel D845GVSR Motherboard
No start up, no bios boot , only "no signal "on screen
Is the CPU fan spinning? if not, check the coolant between the CPU and the cooler (ensure it's not dried up, and replace it if it has or if there is very little there).
May 31, 2008 | AOpen AX4B-533 Motherboard
Intel D845GVSR Motherboard Logo
121 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
