Question about Whirlpool LSR5132PQ Top Load Washer
No aggitation or spin, high pitched noise.
Motor and water drainage are fine, just doesn't aggitate or spin.
  • 242 Answers
Sounds like you have a broken motor coupling , empty the unit , tilt it back against something so you can get a good look under it , the motor is in the middle of the pump[front side] and the gear case[back side] the shaft comes out of both ends of the motor , look for the part that connects the motor and the gear case , it is a small round rubber and plastic piece with prongs , all of the prongs have most likely broke off. , replace this and it should be fine. let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
Washer aggitates poorly when it is loaded
Check belt tension. Motor capacitors weak. Check the spin mode. Finally check the motor.
Apr 03, 2010 | Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Washer will not spin. Does everything else.
If it aggitates, then the tranny and motor coupling is ok. the drive assembly is bad. nintey perent of the no spin problems is motor coupling problem. But since yours will aggitate, then the coupling is fine.
Jul 12, 2009 | Whirlpool Inglis IP4400 Washer
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
